Box fill -interpretation of 12-3034 (2) (b) - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 2 Post By PlugsAndLights
  • 1 Post By B-Nabs
  • 1 Post By MechanicalDVR
  • 1 Post By eddy current
Old 01-09-2017, 11:16 PM   #1
Rewards Points: 83
Default Box fill -interpretation of 12-3034 (2) (b)
EDIT: Sorry - title should have read (2) (c)
I was rereading this rule tonight - I had up to this point taken it to mean that for each flush device box fill was reduced by two conductors. However, on rereading I thought there seems to be some ambiguity in the wording - the way the code reads seems as if you could, say, in a three gang box, count three devices as only totalling two conductors worth of fill - in sum, not for each.
To put it another way, the way it's worded seems to indicate that it's the presence of devices that counts, not the number.
Here's the code:
12-3034 Maximum number of conductors in a box
(2) Except as specified in Subrule (3) and subject to the details given in Subrule (1), boxes of the nominal dimensions given in Table 23 shall not contain more insulated conductors of a given size than permitted by the Table, and the number of conductors shall be reduced for each of the following conditions as applicable:
(a) one conductor if the box contains one or more fixture studs or hickeys;(b) one conductor for every pair of wire connectors with insulating caps (no deduction for one wire connector, deduct one conductor for 2- or 3-wire connectors, two conductors for 4- or 5-wire connectors, etc.);
(c) two conductors if the box contains one or more flush devices mounted on a single strap.
Any thoughts?
Mugs is offline   Reply With Quote
The Following User Says Thank You to Mugs For This Useful Post:
Byte (01-10-2017)
Old 01-09-2017, 11:30 PM   #2
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 1,348
Any thoughts?
The wording isn't very clear...as usual.
I take it to mean that, for example, each switch counts as two wires
unless it's one of those oddball things with 2 switches on one strap.
P&L
Mugs (01-10-2017)
Old 01-10-2017, 09:20 AM   #3
Byte's Avatar
Rewards Points: 346
Wording is clear enough to me but I am an old fart.
One or more devices would cover the gangable boxes and multi switch boxes. The two conductor deduction would cover the whole box, either single, double, etc.
Byte is offline   Reply With Quote
Old 01-10-2017, 05:06 PM   #4
Watt Pusher
B-Nabs's Avatar
Rewards Points: 144
The way I read it is a device that takes up a whole gang is a 2 wire deduction. Whether that device is a singlex receptacle, a duplex receptacle, a single switch, or like P&L mentioned one of those two or three switch on one strap type deals. In other words, if you had a two gang with something
Old 01-10-2017, 05:07 PM   #5
Watt Pusher
B-Nabs's Avatar
Rewards Points: 144
*sorry my computer farted
as I was saying, with something mounted in each gang, that would be 4 wires deducted. 3 gangs with devices in each, 6 wires. etc.
PlugsAndLights likes this.
Old 01-11-2017, 01:05 AM   #6
Byte's Avatar
Rewards Points: 346
No way
Old 01-11-2017, 01:33 AM   #7
Deplorable-Electrician
Rewards Points: 9,142
Originally Posted by Byte View Post
No way
Do you ever agree with anyone?
eddy current likes this.
20 Jan 2017 Truly a great day in American history!
End of an ERROR.... MAGA!
Old 01-11-2017, 05:08 PM   #8
Light Bender
eddy current's Avatar
Rewards Points: 1,020
P&L
I read it as any device attached to one strap = 2 wires. including multiple switches on ONE strap.
B-Nabs likes this.
Old 01-11-2017, 05:12 PM   #9
Light Bender
Here's the code:
Any thoughts?
Pretty clear to me. Table 23 doesn't have dimensions for gangable boxes? They are talking about one box at a time.
Same as if we gang two boxes, the fill is now double. but not indicated on table 23.
Old 01-11-2017, 05:20 PM   #10
Safety Pin Member
Agreed. If my wording wasn't clear, that's what I meant.
So like B-nabs said, 3 gang box with 3 switches is a 6 wire deduction.
P&L
eddy current and B-Nabs like this.
Old 01-11-2017, 05:20 PM   #11
Rewards Points: 114
Code handbook says 2 conductors for any one or more devices on a strap. to me that means 3 devices in a 3 gang box =2 wires. which makes no sense.
mitch65 is offline   Reply With Quote
Old 01-11-2017, 05:56 PM   #12
Light Bender
Here is one device on one strap (each one counts as 2 wires)
[IMG][/IMG]
Here is two devices on one strap(also counts as 2 wires)
[IMG][/IMG]
Basically we count 2 wires for every one of these metal straps, regardless of how many devices are attached to it.
[IMG][/IMG]
edit: unless it is deeper than 2.54 cm of course
B-Nabs likes this.
Old 01-11-2017, 06:01 PM   #13
Rewards Points: 114
I agree that makes more sense but the wording doesn't communicate that.
Old 01-11-2017, 06:06 PM   #14
Light Bender
Sure it does?
" Code handbook says 2 conductors for any one or more devices on a strap"
OR
2 conductors for every metal strap that holds devices, better?
What do you think they mean by "a strap?"
Old 01-11-2017, 06:25 PM   #15
Safety Pin Member
It's simple: Start by knowing what the code actually requires. Then,
read each rule over and over until you find some way that the rule
can mean what you already know it's supposed to mean.
P&L
Pipe fill sicilianiggy General Electrical Discussion 10 08-22-2016 07:33 PM
Box fill for grounding bushings Rowley3068 NEC Code Forum 16 06-19-2016 05:50 PM
box fill... stonewhite NEC Code Forum 8 05-30-2016 12:57 AM
So, what's up with Conduit Fill, Anyways? KennyW General Electrical Discussion 16 05-02-2016 10:56 PM
Conduit fill for water feature fountain Sprink General Electrical Discussion 3 04-27-2016 08:03 PM
