Old 04-18-2012, 04:55 PM   #1
Default Conduit bends
Just wondering if the EMT rule of no more the the equivalent four 90 degree bends applied to EMT bending when either communication or low voltage control wiring is being pulled in the pipe?
Thanks, Justin
jusmac is offline   Reply With Quote
Old 04-18-2012, 05:04 PM   #2
Chief Electron Relocator
Not sure about the CEC, but the NEC doesn't have any exception.
Old 04-18-2012, 05:10 PM   #3
cdnelectrician's Avatar
Thanks, Justin
I don't think there is any exception in the CEC either.
Old 04-18-2012, 05:16 PM   #4
Boomer's Avatar
Why would you want to? We pull a lot of control wire for temp. control and that wire will pull just as hard as THHN when pulling through 180+ degrees.
Boomer is offline   Reply With Quote
Old 04-18-2012, 05:17 PM   #5
CADPoint's Avatar
Send a message via AIM to CADPoint Send a message via Yahoo to CADPoint
Put a box or a "C" or "L".
Old 04-18-2012, 07:31 PM   #6
wcord's Avatar
Thanks, Justin
60-302 Raceways
Raceways for communication conductors shall be installed in accordance with the requirements of Section 12
and, if metal, shall be grounded in accordance with Section 10.
The Following User Says Thank You to wcord For This Useful Post:
The_Modifier (04-18-2012)
Old 04-18-2012, 09:12 PM   #7
Electron Pathway Engineer
Damn it wcord you beat me to it. lol
Old 04-19-2012, 06:45 AM   #8
wcord's Avatar
Sorry lol
Does anyone know the formula for concentric offset bends lewis hinkle General Electrical Discussion 22 03-04-2012 05:30 AM
360 degrees in bends is code... danickstr General Electrical Discussion 14 03-26-2011 04:04 AM
Parallel Bends and MDShunk Frasbee Commercial Electrical Forum 38 03-22-2011 04:47 AM
PVC: factory vs. Heating bends zoltan General Electrical Discussion 37 08-14-2010 05:58 AM
