Disconnect near sink - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
  • 2 Post By MechanicalDVR
  • 3 Post By Blitzer
  • 1 Post By eddy current
  • 1 Post By 99cents
  • 4 Post By PlugsAndLights
  • 1 Post By Azachi
Old 01-06-2017, 09:11 AM   #1
Rewards Points: 20
Default Disconnect near sink
I'm looking through the code and I can only find codes on receptacles & switches near a sink.
I have a 600v 30A disconnect and a motor starter. The facility installed a sink a foot away. It seams ok to me, what do you guys think?
Blitzer is offline   Reply With Quote
Old 01-06-2017, 09:31 AM   #2
Byte's Avatar
Rewards Points: 912
The problem is not electrical...somebody else installed a sink after the fact.
Byte is online now   Reply With Quote
Old 01-06-2017, 09:32 AM   #3
Rewards Points: 20
I was half way finished the job and I left for a few days to go to another job. I came back to find the sink installed. Electrically speaking I'm looking at the code issues, not the plumbers.
Old 01-06-2017, 09:34 AM   #4
Byte's Avatar
Rewards Points: 912
Plumber's problem
Old 01-06-2017, 09:38 AM   #5
Deplorable-Electrician
Rewards Points: 24,368
Plumber's problem
Is that in the CSA too?
Old 01-06-2017, 09:44 AM   #6
Rewards Points: 20
Plumber's problem
I'll try saying that to ESA, followed by me spitting some chewing tobacco on his feet.
Old 01-06-2017, 09:50 AM   #7
Byte's Avatar
Rewards Points: 912
You are installing switches. What is the difference if you install a switch near a sink?
Old 01-06-2017, 10:11 AM   #8
Light Bender
eddy current's Avatar
Rewards Points: 1,280
Can't think of a code that says we must keep clear of a sink?
Receptacles near sink 26-700(11)
lighting equipment in damp locations (switches) 30-320(3)
Borgi likes this.
Old 01-06-2017, 10:12 AM   #9
Light Bender
Lol
Old 01-06-2017, 10:12 AM   #10
Rewards Points: 8,104
I got trapped by an inspector once with a panel in a laundry room. On final inspection he said the panel was too close to the sink. I asked him for a code reference and he gave me "poor workmanship". I couldn't argue with him because he was the only inspector in town. That was an expensive fix.
Byte likes this.
Old 01-06-2017, 10:50 AM   #11
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,510
The code ref's provided by others above are related but IMO don't directly
apply to this situation. However, even without specific rules disallowing this
location, it's certainly questionable. @Blitzer 's initial post suggests to me
that he's not that happy with the location and wouldn't have put it there
had he known the sink was going in.
I guess the prudent thing to do is to call the inspector, explain the situation,
and see what he says.......Either that or just move it and feel better.....
As far as the code goes, inspector can fail pretty much anything using 2-112
if he/she feels that it's clearly bad practice but was missed in the code
because it can't cover every situation.
P&L
Old 01-06-2017, 10:48 PM   #12
Rewards Points: 82
P&L
didn't even know a code like 2-112 existed until i went in the code and read it, lol
PlugsAndLights likes this.
Azachi is offline   Reply With Quote
Old 01-07-2017, 01:24 AM   #13
Rewards Points: 13,626
So the Plans & Specifications were written on a wet napkin ?
I thought so.
You NEVER looked at the P sheets ?
Or the A sheets ?
Usually the BLOCKING for the sink makes it idiot obvious that "something wet comes this way."
BTW, switches are placed around sinks -- all-the-time.
You have a (surface mounted) switch that has some fuses. It looks weird. But, it's not a hazard.
Old 01-07-2017, 01:27 AM   #14
2-112 is NOTHING.
Wait until you run into Rule 303.
I'll let Breaker Morant explain it to you.
Blitzer (01-11-2017)
Old 01-11-2017, 09:59 AM   #15
Rewards Points: 20
I'm installing a disconnect.
The code talks about sinks and switches in relation to controlling lights. Section 30 is lighting equipment.
Service disconnect for Hot tub (Chicago Code) JupoiUrzici General Electrical Discussion 2 12-22-2016 10:08 PM
480VAC Coil and 250VAC Rated Contact NJWVUGrad General Electrical Discussion 5 09-19-2016 02:58 PM
Spa Disconnect and fuse question DuskIndustries General Electrical Discussion 9 06-18-2016 08:28 AM
115 VAC disconnect - should I break both hot & neutral? Paul Kraemer General Electrical Discussion 11 01-22-2016 10:21 PM
