Minimum 2-pole circuit breaker required? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree17Likes
Old 02-16-2017, 11:07 PM   #21
Deplorable-Electrician
Rewards Points: 27,846
Originally Posted by Navyguy View Post
Five is the answer I think.
1 for the 6-15R receptacle
1 for the heater
1 for the HWT
2 for the splits - the third split can feed off the first or second split.
Now you could put the HWT on a single pole (4500 watts is (240 volts) two pole, 1500 watts is (120 volts) single pole?) so that could bring you back to four I suspect. You also probably could say the same for the BB heater, I suspect it would be dual voltage rated, but there was only one wattage rating in the question.
I think in the "real world" most of us would have used 6 - 2 pole breakers.
Cheers
John
That is the real answer!
Navyguy likes this.
Old 02-16-2017, 11:08 PM   #22
Rewards Points: 226
You ever wire like that?
No, I don't split anything other than the DW/GD recepts.
If a man whispers in a forest and there's no wife around, is he still wrong?
ben franklin is offline   Reply With Quote
Old 02-16-2017, 11:08 PM   #23
Rewards Points: 82
Originally Posted by eddy current View Post
Two splits per circuit is in residential only.
26-722(b)(i)
26-724(b)(i)
i was like what kinda code book he have:P
Azachi is offline   Reply With Quote
Old 02-16-2017, 11:09 PM   #24
Light Bender
eddy current's Avatar
Rewards Points: 1,386
Originally Posted by Azachi View Post
26-724(b)(i)
Oops. (2012)
Old 02-16-2017, 11:12 PM   #25
Yeah man that is my thought.
Old 02-16-2017, 11:12 PM   #26
Rewards Points: 82
still seems the answer is 5 though so maybe ESAT will get back to me and inform me
Old 02-16-2017, 11:15 PM   #27
Light Bender
No its 4!!!
In commercial you can put up to 12 splits on one 2-pole breaker.
Read the question. It asks for the MINIMUM number of 2 pole breakers required. Of course no one would wire a room that way but they ask for the MINIMUM.
glen1971, B-Nabs, Azachi and 1 others like this.
Azachi (02-16-2017)
Old 02-16-2017, 11:18 PM   #28
No its 4!!!
You can but why would you?
Canadians..........and their strange rules of engagement...
Azachi (02-16-2017)
Old 02-16-2017, 11:18 PM   #29
Rewards Points: 82
No its 4!!!
ah, see i didnt know that, i knew 12 receptacles could be put on a breaker i just didn't know it also applied split receptacles as well
eddy current likes this.
Old 02-16-2017, 11:20 PM   #30
Rewards Points: 82
i got so carried away by reading all the answers i totally forgot the question since we was all brainstorming lol
Old 02-16-2017, 11:20 PM   #31
Light Bender
Every question is a trick. It's an English test in a lot of ways.
glen1971 likes this.
Old 02-16-2017, 11:22 PM   #32
Rewards Points: 82
yeah it really is
Old 02-17-2017, 02:40 AM   #33
Byte's Avatar
Rewards Points: 930
Hey guys, as usual you're always fast to respond and always expanding my knowledge in the trade but I came upon a question in my ESAT that's left me stumped. I even talked it over with my journeyman and he was in the same boat as myself so now I'm seeking the knowledge of the elders:P
My code question goes as follows:
An electrical installation is being planned for a room in a commercial occupancy. The room is to contain the following: Wall switch to switch ten 120V, 4ft, 2-lamp fluorescent fixtures; Three 5-15R split circuit receptacles; One 240V, 3000W baseboard heater controlled by a wall thermostat; One 4500/1500W, 240V electric hot water heater One 6-15R receptacle. What is the minimum number of 2-pole circuit breakers that would be required?
a) 2
b) 3
c) 4
d) 5
I selected d) 5 because of the 3 split receptacles, the 240V baseboard heater and the 240V hot water heater. Now i know the 240V baseboard heater can be hooked up to a single pole thermostat but isn't it still required to come off a 2 pole breaker. Any help would be appreciated because i hate not knowing
The ESAT answer was c) 4
4 is what I get now. I forgot that the question was about how many 2-pole breakers.
Byte is offline   Reply With Quote
Old 02-20-2017, 08:46 PM   #34
daks's Avatar
Rewards Points: 120
Not strange, our government under-funds, so we have to save our bullets and hit what we shoot at the first time.
I always tell people;
First thing you have to do when practicing for the ESAT is put how you SHOULD or WANT to do it in a deep dark place.
It is not a test of good practice or common sense it is a test of how well you identify key words and apply them from the code book, not real life, not intelligently but to the code book.
Byte likes this.
daks is offline   Reply With Quote
Creating a "service call kit" for your second truck HackWork Business, Marketing, and Sales 41 04-07-2017 12:12 PM
Arc fault option Anathera General Electrical Discussion 175 07-08-2016 06:35 PM
what is the differences between inverse time circuit breaker and regular breaker? mike883 General Electrical Discussion 17 05-22-2016 03:47 PM
Upgrading and outdoor screw-in fuse box to a circuit breaker type box Jimmi328 Residential Electrical Forum 2 03-26-2016 08:09 PM
Is this overkill? MTW NEC Code Forum 81 03-20-2016 09:26 PM
