Neutral req'd in switch box??? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree64Likes
Old 10-15-2016, 12:13 PM   #1
power's Avatar
Rewards Points: 441
Default Neutral req'd in switch box???
Admittedly, I know little about residential as we NEVER touch it.
Anyways, I was told by another electrician that a neutral is needed in the switch boxes when your installing 3-way switches in them! I never heard of this. Depending on how you route the cable, I thought a 14/3 NMD is ok for a 3-way switch, that is, two travelers and the remaining hot or light feed.
Is this true?
power is offline   Reply With Quote
Old 10-15-2016, 12:18 PM   #2
Big nosed attic troll
Majewski's Avatar
Rewards Points: 1,114
Depending on the routing, it might not happen. Maybe this guys local county had amended rules?
power likes this.
Old 10-15-2016, 12:47 PM   #3
Rewards Points: 138
Is this true?
It is true in the USA but not sure about Canada.
I am moving this thread to the Canadian forum
Old 10-15-2016, 02:11 PM   #4
Rewards Points: 494
With all the smart switches / devices available, and the fact that adding a neutral after usually would be painful, it's not a bad idea anyway.
Jmcstevenson, power, Borgi and 2 others like this.
Old 10-15-2016, 02:14 PM   #5
360max's Avatar
Chicago
Old 10-15-2016, 02:32 PM   #6
Rewards Points: 2,028
We should have a Hawaii Forum since we gave Canada one. That way I can start threads about having neutrals in switch boxes, and then answer myself with a post reply that hell no, as the most modern place in the world , we rely on the 2008 Nec and there is no reason to have any neutrals in switch boxes, and to hell with alarm installers. 2008 Rocks.
power and Majewski like this.
Old 10-15-2016, 02:34 PM   #7
Rewards Points: 4,188
Is this true?
Tell him to look it up in his code book. It's in Section 13.
The Following 3 Users Say Thank You to 99cents For This Useful Post:
glen1971 (10-16-2016), power (10-15-2016), The_Modifier (10-16-2016)
Old 10-15-2016, 03:14 PM   #8
Borgi's Avatar
Rewards Points: 2,602
Not required in Canada under the CEC, but your local bylaws may.
As mentioned above, not a bad idea, if you consider the new products available.
On a safety note, some devices use the bond wire as the neutral. Not accepted practice by me. US, maybe! 😜
Borgi
Blitzer likes this.
If a man aint a feared he's a fool!
Borgi is offline   Reply With Quote
Old 10-15-2016, 05:43 PM   #9
wcord's Avatar
Rewards Points: 580
Borgi
About the time 2012 edition came out, there were rumors that a neutral would be required in all switch boxes.
The majority of motion sensors and timers needed a neutral. The electronic low voltage dimmers also, and still require a neutral. There is a wide selection of motions and timers now, which rely on the ground.
I agree with Borgi, using the ground is bogus.
I've made it a habit to install a neutral in all switch boxes, including the commercial 347v.
Saves grief later when the customer later on, wants motion sensors or a device which requires a neutral. (Then I can charge, for adding the neutral, on the CO )
Be careful what you wish for, you just may get it.
The Following User Says Thank You to wcord For This Useful Post:
Borgi (10-15-2016)
Old 10-15-2016, 06:25 PM   #10
360max's Avatar
Hawaii.is.a.nice.place.to.retire.our.homeless.to
Majewski likes this.
Old 10-15-2016, 08:29 PM   #11
power's Avatar
Rewards Points: 441
splatz and Borgi: I think you guys are totally right! If it isn't required now, it would be a good idea. I suspect some people are just grounding the neutral (from the device) if they don't have one in the switch box.
Old 10-15-2016, 08:39 PM   #12
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 1,288
No requirement for neutral in a switch box. This applies regardless of
res or commercial and also single pole or SPDT (3-way) or for that matter,
DPDT (4-way).
The arguments for running a neutral where it isn't needed seem weak to me.
I doubt anyone has opened any of the hundreds of switches I've done this way
looking for a neutral.
YMMV
P&L
As far as possible, without surrender, be on good terms with all persons. Speak your truth quietly and clearly; and listen to others, even to the dull and the ignorant; they too have their story. Avoid loud and aggressive persons; they are vexatious to the spirit. ~Desiderata
Old 10-15-2016, 08:52 PM   #13
Majewski's Avatar
Dennis where is it required?
Old 10-15-2016, 09:22 PM   #14
Watt Pusher
B-Nabs's Avatar
Rewards Points: 122
As stated above not required by code, but my general practice in commercial is to rough in all single switches with 3 wire to accessible ceiling. It has saved me more than once, and worst case scenario you have one spare wire a few feet long. In my mind that's well worth saving the headache later on if it's needed.
Old 10-15-2016, 10:33 PM   #15
Majewski's Avatar
Dennis said it was true to the op. That's why I asked for clarification.
Old 10-16-2016, 12:43 AM   #16
corn-fused
papaotis's Avatar
Rewards Points: 194
it is in the nec, cant think of the # at the moment. i think it started with the 2014. i wont be here long, this sight is moving so slow im falling asleep!
Old 10-16-2016, 12:56 AM   #17
Majewski's Avatar
Goto bed old man!
Old 10-16-2016, 01:02 AM   #18
corn-fused
papaotis's Avatar
Rewards Points: 194
old man? why if was as old as i feel id be almost dead! oh, wait, i am
Old 10-16-2016, 09:15 AM   #19
Light Bender
eddy current's Avatar
Rewards Points: 1,016
For commercial, I install deep 4x4's with a plaster ring. Run 3/4 conduit from the box up above the ceiling tiles and install another box. That way you can push whatever wires you need in the conduit when the designer finally decides on a type of dimmer, low voltage, motion whatever.
power and splatz like this.
Old 10-16-2016, 10:15 AM   #20
Borgi
The low amount of current drawn by a typical dimmer, etc. through the bond is of no concern. Try putting a motion sensor on a ground fault protected circuit, though. Then you have a problem .
3way switch used as a bypass Anathera General Electrical Discussion 20 06-21-2016 01:33 AM
Conductor Electek inc General Electrical Discussion 25 05-05-2016 12:02 AM
Neutral required to be ran to generator? lynes.nathan Canadian Electrical Code Forum 7 03-01-2016 10:10 PM
115 VAC disconnect - should I break both hot & neutral? Paul Kraemer General Electrical Discussion 11 01-22-2016 11:21 PM
