Neutral req'd in switch box??? - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree64Likes
Old 01-08-2017, 11:29 PM   #41
Rewards Points: 33
Most LED dimmers call for a neutral wire also, but then there is this:
https://community.smartthings.com/t/...-neutral/20699
arthur is offline   Reply With Quote
Old 01-09-2017, 11:03 AM   #42
Byte's Avatar
Rewards Points: 346
Way too much electronics nowadays. I would rather go back in time and sit at the kitchen table playing cards and listen to the radio that is plugged into this:
electricguy and splatz like this.
Byte is offline   Reply With Quote
Old 01-09-2017, 01:18 PM   #43
Rewards Points: 1,278
We still have radios and cards. We even kept our table.
in Order to form a more perfect Union
Old 01-09-2017, 07:45 PM   #44
Rewards Points: 54
At the risk of repeating someone else's answer, the neutral will be needed should a regular switch be replaced with an LED - equipped motion sensor or dimmer. I learned the hard way.
billymac93 is offline   Reply With Quote
Old 01-09-2017, 07:56 PM   #45
Rewards Points: 1,530
General contractors really don't care if there is a neutral in the switch boxes it increases the cost to them.
Old 01-09-2017, 11:03 PM   #46
Rewards Points: 83
Originally Posted by power View Post
Admittedly, I know little about residential as we NEVER touch it.
Anyways, I was told by another electrician that a neutral is needed in the switch boxes when your installing 3-way switches in them! I never heard of this. Depending on how you route the cable, I thought a 14/3 NMD is ok for a 3-way switch, that is, two travelers and the remaining hot or light feed.
Is this true?
This just came up at work recently. I'm curious - is there a reason to think that 4-028 doesn't apply to this question?
it says:
4-028 Installation of neutral conductor
Where a service, feeder, or branch circuit requires a neutral conductor, it shall be installed
(a) in all separately enclosed switches and circuit breakers;
(b) in all centres of distribution associated with the circuit;
Mugs is offline   Reply With Quote
Old 01-10-2017, 12:08 AM   #47
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 1,340
it says:
I think what they really mean here is disconnect, not regular wall switch.
Picture a 3ph 4wire disconnect.
P&L
electricguy likes this.
The Following 2 Users Say Thank You to PlugsAndLights For This Useful Post:
electricguy (01-10-2017), Mugs (01-10-2017)
Old 01-10-2017, 12:21 AM   #48
still in business
sbrn33's Avatar
Rewards Points: 790
Really? I put them in everyday and very few need a noodle.
It's just that simple
Old 01-10-2017, 03:11 AM   #49
Rewards Points: 10,524
With a NIC of Byte... okay...
Old 01-10-2017, 01:43 PM   #50
Borgi's Avatar
Rewards Points: 2,602
it says:
Key phrase, " requires a neutral conductor ".
In many cases the neutral is not required, ( in the switch box for example ), but with all the new products on the market, it may be required.
Be sure to carefully read the manufacturers' instructions.
Borgi
If a man aint a feared he's a fool!
Borgi is offline   Reply With Quote
Old 01-10-2017, 10:58 PM   #51
Rewards Points: 83
Borgi
For the sake of being disagreeable, I would say that the key phrase is at the start, I think. "where a service, feeder, or branch circuit requires a neutral conductor." I would venture to say that covers pretty much any 120V cct. Nowhere is the requirement for the neutral at a location predicated on the device being used at that location.
Old 01-10-2017, 11:20 PM   #52
Borgi's Avatar
I am open to a discussion.
Have a look at the definition for " branch circuit ", and " outlet " first, then get back to us.
In my apprentice days in residential, I always fed the switch first, so a neutral was always present at the switch box. But, later in life, I didn't care as much.
Now, it may be back to " feed the switch ".
The CEC gives us the option.
So far!
Borgi
Old 01-10-2017, 11:53 PM   #53
Safety Pin Member
Here's another way of looking at it: The practice of not having neutrals
at all switches is common and has been so forever. If a neutral were
required, wouldn't some inspector somewhere have mentioned it by now?
Defects for this sort of thing would be common knowledge on this forum
and elsewhere.
Also, 4-028 is not new.
And finally, have you checked the CE code handbook?
P&L
Old 01-11-2017, 12:58 AM   #54
Byte's Avatar
Rewards Points: 346
(c) with all connections to the neutral being made in the enclosures and centres; and
(d) in such a manner that any neutral conductor can be disconnected without disconnecting any other neutral
conductor.
Section 0
Branch circuit — that portion of the wiring installation between the final overcurrent device protecting the circuit and the outlet(s).
Literary it reads that a neutral is required in every box of the branch circuit...does it not?
Old 01-11-2017, 10:15 AM   #55
Band Member
emtnut's Avatar
Rewards Points: 6,416
"If required" ... Think about hwt's , A/C , .... 240V loads
If you follow this guys advice ... you could die a really slow painful death
Old 01-11-2017, 10:32 AM   #56
Byte's Avatar
Rewards Points: 346
I was thinking of a branch circuit powering lights. The switch box is in the branch circuit so does the code require a neutral in that box? That would mean running a 3-wire as a switch leg.
Very confusing. 2-wire switchlegs are all over the place.
Old 01-11-2017, 10:38 AM   #57
Band Member
emtnut's Avatar
"if required"
Not required on a switch loop.
I don't like switch loops ... but that's the code.
If someone changes to a fancy programmable dimmer ... then now they need the noodle ... someone has to install one
Old 01-11-2017, 10:40 AM   #58
Byte's Avatar
Rewards Points: 346
"if required"
Do you know where I can find the rule? Thanks for your help.
Old 01-11-2017, 10:44 AM   #59
Band Member
emtnut's Avatar
4-028 !! It says 'where required'
Byte (01-11-2017)
Old 01-11-2017, 11:03 AM   #60
Byte's Avatar
Rewards Points: 346
Is this true?
I finally found the answer you need from Appendix B:
Neutral
By definition, a neutral conductor of a circuit requires at least three conductors in that circuit. However, in the trade, the term “neutral conductor” is commonly applied to the conductor of a 2-wire circuit that is connected to a conductor grounded at the supply end. Care should therefore be taken in the use of this term when applying
the Code.
4-026 is written for three or four wire circuits, not two wire circuits.
emtnut likes this.
3way switch used as a bypass Anathera General Electrical Discussion 20 06-21-2016 01:33 AM
Conductor Electek inc General Electrical Discussion 25 05-05-2016 12:02 AM
Neutral required to be ran to generator? lynes.nathan Canadian Electrical Code Forum 7 03-01-2016 10:10 PM
115 VAC disconnect - should I break both hot & neutral? Paul Kraemer General Electrical Discussion 11 01-22-2016 11:21 PM
