Old 06-13-2012, 07:31 PM   #1
Smile Sub Panels
In Etobicoke, is it allowed a 60 amp sub panel in wooden shed feeding a 1hp 115 volt pool pump, a pool heat pump pulling 20 minimum ampacity 30 max fuse and a 15amp cicuit feeding two recepticals and a light, the run is 100 feet from main 100amp panel to sub panel, will be using mnwu 6/3 from house to under ground in 1 1/4 pvc under grass 18" deep. I was told that 40 to 50 amp sub would work?
tonywarp is offline   Reply With Quote
Old 06-13-2012, 08:34 PM   #2
Heavily Armed Member
HARRY304E's Avatar
Unless the Canada code is different then it sounds Okay..
Welcome to the forum..
Old 06-13-2012, 08:37 PM   #3
Check the Canadian Code. Here in the States, we have to have an insulated ground wire in the feeder and branch circuits to pool equipment.
Old 06-13-2012, 09:03 PM   #4
ampman's Avatar
a pool in canada
i'am going to make you lick a white dog turd
ampman is offline   Reply With Quote
The Following User Says Thank You to ampman For This Useful Post:
k_buz (06-16-2012)
Old 06-13-2012, 09:44 PM   #5
Can't run nmwu in pvc in Canada.
xlink is offline   Reply With Quote
Old 06-13-2012, 10:15 PM   #6
wcord's Avatar
Which code rule refers to that?
The only restriction I can think of is that you can't run NMD in any conduit underground'
AND PVC can not be run in insulation.
Old 06-13-2012, 10:19 PM   #7
What's the point of using the PVC if you are running nmwu?....
arni19 is offline   Reply With Quote
Old 06-13-2012, 10:44 PM   #8
Table 19
Old 06-14-2012, 09:21 AM   #9
I've wondered about this as well, and haven't had a straight answer. My thinking is you can't do the whole run in PVC, but shorter lengths for mechanical protection is okay.
12-902 says conductors shall be of types suitable for use in raceways as indicated in Table 19. And NMWU isn't listed as suitable for raceways.
But then, I haven't seen an inspector pay attention/call that either....when contractors have done that....but then they missed bigger problems than that.....
sprdave is offline   Reply With Quote
Old 06-14-2012, 09:34 AM   #10
Only reason I can guess is the PVC acts as a chase underground in case they want to add/change anything without having to trench again?
local134gt is offline   Reply With Quote
Old 06-14-2012, 10:09 AM   #11
Cool sub panels
I don't know what part of ontario your in. But in Etobicoke the rule is you must pertect nmwu with conduit when under ground
Old 06-14-2012, 10:53 AM   #12
Electric Al
oldtimer's Avatar
I don't know what part of ontario your in. But in Etobicoke the rule is you must protect nmwu with conduit when under ground
B T W, N M W U is direct burial cable!
I fixed the spelling for you.
I'd rather have a bottle in front of me , than a frontal lobotomy. ( Quote from Tom Waits. )
Old 06-14-2012, 06:52 PM   #13
U rated for underground. It is underground. Good.
kaboler is offline   Reply With Quote
Old 06-14-2012, 07:44 PM   #14
When did etobicoke get its own rules?
CanadianSparky is offline   Reply With Quote
The Following User Says Thank You to CanadianSparky For This Useful Post:
Mikeinont (06-16-2012)
Old 06-14-2012, 11:14 PM   #15
This makes zero sense..are you telling me that if you are using a usei or useb for a service entrance relocate on a residence you have to run it in PVC underground? What a pain there would be no point to using a direct burial wire at all. Not to mention your sub panel is protected by an over current device, unlike the service conductors that are at the mercy of the transformers potential.
Old 06-14-2012, 11:25 PM   #16
cdnelectrician's Avatar
This makes no sense, Etobicoke follows the OESC just like the rest of Ontario does!
Old 06-14-2012, 11:31 PM   #17
Do you guys use usei or useb in the ground for homes or do you have some stricter rules on service entrance wires?
Old 06-15-2012, 03:50 PM   #18
In Toronto, hydro usually brings the service conductors right into the meter base for an underground service. But yes USEB is commonly used, as long as it is buried to the depth required by code and has red marking tape and the proper backfill it's no problem.
Old 06-15-2012, 05:28 PM   #19
You aren't allowed to use two different fuses in a panel. I assume you mean breakers.
Your load calculations seem fine.
Make sure your underground wiring complies with section 68.
Your journeyman should be there to answer any other questions you have.
Cujo is offline   Reply With Quote
Old 06-16-2012, 06:41 AM   #20
Mikeinont is offline   Reply With Quote
MLO Panels klein NEC Code Forum 4 05-26-2011 05:14 PM
Panels Robert@ipi General Electrical Discussion 15 03-13-2011 05:15 PM
Replacing 50 year old westinghouse panels with newer panels SPINA ELECTRIC Services and Service Equipment 1 08-08-2010 01:20 PM
How many panels do you need now ? MDShunk General Electrical Discussion 33 12-18-2009 12:58 PM
FPE Panels nolabama Services and Service Equipment 5 10-01-2008 11:18 PM
