underground gas electrical separation ontario - Electrician Talk - Professional Electrical Contractors Forum
Like Tree16Likes
Old 04-20-2017, 09:59 PM   #1
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,876
Default underground gas electrical separation ontario
Looking for document with underground gas - electrical separation
requirements. This will be between house and garage, if it matters.
Thanks,
P&L
Old 04-20-2017, 10:24 PM   #2
RePhase277's Avatar
Rewards Points: 4,576
I've seen that document here somewhere... but the ESA's website said this:
underground gas electrical separation ontario-screenshot_2017-04-20-21-21-48.jpg
Old 04-20-2017, 10:28 PM   #3
Rewards Points: 9,970
Nothing in the CEC. In my province we have a Standata item that says 300mm of compacted soil or separation with a 50mm treated plank.
Old 04-20-2017, 10:31 PM   #4
I'm impressed Rephase and it's not even in Section 13 .
MechanicalDVR and RePhase277 like this.
Old 04-20-2017, 10:37 PM   #5
Safety Pin Member
Not the first time I've noticed your good at tracking down web info
P&L
RePhase277 likes this.
Old 04-20-2017, 10:47 PM   #6
RePhase277's Avatar
Let's be realistic; Section 13 can only hold so much data. It's the footnotes to Section 17 where all the action is.
Navyguy, 99cents and glen1971 like this.
Old 04-20-2017, 11:05 PM   #7
Deplorable-Electrician
Rewards Points: 2,128
LOL!
Old 04-21-2017, 06:45 AM   #8
Band Member
emtnut's Avatar
Rewards Points: 8,252
Thanks,
P&L
The 1 foot separation is for cable.
In case it applies here ... It's 3 feet separation from the meter (gas or hydro)
all wiyht, rho sritched mg kegtops awound
Old 04-21-2017, 06:50 AM   #9
You bury the plank?
Old 04-21-2017, 07:20 AM   #10
You bury the plank?
Yeah, I have run them side by side with the wood between them.
Old 04-21-2017, 07:23 AM   #11
I don't get the logic in that. Once the wood has the moisture level of the ground it loses any insulating properties.
Treated or not it will not hold up when buried very long.
Strange requirement.
Old 04-21-2017, 07:24 AM   #12
RePhase277's Avatar
I thought the point of the plank was to let you know before you reached the utilities? If you have the plank on the same level as the pipes and cables, what's the point?
Old 04-21-2017, 08:04 AM   #13
I don't write the rules, I just follow them (occasionally).
Old 04-21-2017, 08:11 AM   #14
Nobody is blaming you for them, they just seem foreign to us.
Old 04-21-2017, 08:13 AM   #15
It seems foreign to me as well .
Old 04-21-2017, 08:16 AM   #16
As it should to any thinking man!
Old 04-21-2017, 08:38 AM   #17
Band Member
emtnut's Avatar
We don't have the 2X6 exception here, but I'm pretty sure that if you use a plank with 6" clearance, the electrical has to be buried lower than the gas.
The plank helps to stop sparks from the backhoe blowin things up !
Old 04-21-2017, 09:10 AM   #18
Safety Pin Member
I've never used a plank. Not yet anyways. But the code allows PT planks
to be used for mechanical protection. Either PT planks (38mm thick and
extending at least 50mm on each side), or concrete, can be used to
reduce the required burial depth by 150mm. Other methods can be used
to reduce this further.
While the code doesn't seem to specify this, the logical place
for the plank is above the screened material, before the rough stuff
goes in.
Code ref 12-012(2) and (3)
Whether this provides adequate protection over time, I have no idea.
BTW, burial depths without protection vary between 450mm and 900mm
(for voltages less than 750V) depending on things like: cable, conduit,
vehicular areas.
P&L
Old 04-21-2017, 09:12 AM   #19
goes in.
vehicular areas.
P&L
Yeah man, toss in a little logic!
Old 04-21-2017, 09:32 AM   #20
Band Member
emtnut's Avatar
We're talking 2 different things here !
First thing is U/G wiring that is not at required depth, you can use a plank and not have it as deep.
The other is separation between gas and electric, assuming they are deep enough, there are provisions in some provinces to allow them to be closer than 1' (up to 6") if you use a plank
*edit* @PlugsAndLights ... I'd call Hydro One or Enbrigde gas ... they have the final say
Connecting Grid-tied, PV system to the electrical system katwalatapan Alternative Energy Forum 13 06-15-2016 07:57 PM
PVC underground kd129 Commercial Electrical Forum 25 06-03-2016 12:14 AM
Canadian Electrical Code 8-104 (8) - underground conductor sizing jjdoerksen Canadian Electrical Code Forum 7 04-19-2016 03:50 PM
Applied Minds: Electrical Engineering Technician opportunity tlindsey Looking To Hire 0 01-21-2016 04:56 PM
