Are conduit bodies a fire hazard? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 4 Post By joebanana
  • 1 Post By macmikeman
Old 04-04-2016, 10:06 PM   #1
Default Are conduit bodies a fire hazard?
A co worker of mine told me that LB conduit bodies are the number one cause of electrical fires on photovoltaic systems. Primarily on the dc conductors. Has anyone else heard of this? I can't find any information regarding this potential fire hazard.
Kedgren is offline   Reply With Quote
Old 04-04-2016, 10:25 PM   #2
Speedy Petey's Avatar
Rewards Points: 2,134
What was his logic??
Interestingly, I heard driving a car is the number one cause of gall stones.
Old 04-04-2016, 10:39 PM   #3
Rewards Points: 428
Sounds like nonsense. I have seen 600 volts DC feeding lights in some train stations and they are in 1 rigid conduit and have LB, LL,LR and C fittings and they have never created fires.
bobbarker is offline   Reply With Quote
Old 04-04-2016, 10:40 PM   #4
gnuuser's Avatar
Rewards Points: 1,616
only if they forgot to ream the conduit or install bushings,
the primary cause of fires in pv systems is using undersized or incorrect wire.
wire needs to be rated for dc
although the voltage is lower, the current is much higher than higher voltage ac circuits
many tend to forget the conduit fill rules and use conduit too small
conduits should never be painted as it can cause heat retention and insulation breakdown.
Old 04-04-2016, 10:49 PM   #5
Rewards Points: 2,189
I've noticed, over the years, some "co-workers" are full of fertilizer.
Old 06-15-2016, 11:19 AM   #6
Rewards Points: 88
Default not be square, like curves
The only reason there would be a hazard is using rigid wire and making square bends go to stranded wire that is in manufacturing. Heat will not go around square bends and will cause a premature breakdown of insulation.
nom-board is offline   Reply With Quote
Old 06-15-2016, 11:36 AM   #7
Rewards Points: 3,340
I think the number one cause of fire on photovoltaic systems is photovoltaic panels. ................. .. . ... It's deep.
backstay likes this.
Old 06-15-2016, 11:51 AM   #8
NRA Member
backstay's Avatar
Rewards Points: 794
I thought it was 1/2 conduit?
Old 06-15-2016, 03:02 PM   #9
Rewards Points: 88
Default poor installation
Yes poor installation but rocks and bullets baseball size hail don't help either. Not to mention rodents.
Circuit Tracer for Conduit A Little Short Tools, Equipment and New Products 4 03-31-2016 09:54 PM
Fire Alarm How To Book LanceBass General Electrical Discussion 19 03-26-2016 04:40 PM
Varaluz Recalls Longfellow Light Fixtures Due to Fire Hazard guest Recalls, Safety Notices and References 3 01-31-2016 01:26 PM
locating conduit or LV cable behind wall or missing conduit end? lortech Structured Wiring 3 01-18-2016 12:35 PM
