Old 05-02-2012, 03:53 AM   #1
animal lover /rat bastard
wildleg's Avatar
Default DIY solar panels
later on this year I'm thinking about playin around with some solar on my house, maybe building some panels from 6x6 poly. anyone done this ? comments, suggestions, advice ? (I haven't done any solar or wind stuff, so I have to get up to speed on the grid tie)
3rdgenwireman (05-03-2012)
Old 05-02-2012, 07:20 AM   #2
NRA Member
backstay's Avatar
PV panels are under $2 a watt now. Why would you try to build your own?
When "deleted" called the Seals, they killed Bin Laden. When the Seals called "deleted", he denied them.
Old 05-02-2012, 05:25 PM   #3
wildleg's Avatar
for fun. I am still conducting experiments to determine the detrimental effects of alcohol on common work and production tasks (since it is no longer politically correct to do this at work)
The Following 4 Users Say Thank You to wildleg For This Useful Post:
GreenElectrician (04-17-2013), s.kelly (05-04-2012), stuiec (05-05-2012), T.J. (05-07-2012)
Old 05-02-2012, 05:37 PM   #4
BBQ
BBQ's Avatar
Step it up a bit, http://www.popsci.com/diy/article/20...uclear-reactor
Old 05-02-2012, 05:55 PM   #5
NRA Member
backstay's Avatar
Originally Posted by BBQ
I wonder how many ideas like this produced positive power output, but then was buried by big business? I'm thinking along the line of "free energy would destroy the world economy" BS.
Old 05-02-2012, 08:24 PM   #6
wildleg's Avatar
that's a good idea, but in reality a reactor that small doesn't produce sustainable fusion - it is just to show that fusion takes place. you need a reactor the size of a large rec room for a decent reactor, and when you add the "chernobyl" component (I can just see my wife turning off, say, the cooling system because it is too noisy), I'm gonna stick with playing around with some PV. I'm serious about the original post, tho, if anyone has any helpful hints or links they want to share.
Old 05-02-2012, 08:38 PM   #7
1,000,000th Poster
Big John's Avatar
LMAO.
-John
The Following 2 Users Say Thank You to Big John For This Useful Post:
dronai (05-05-2012), Modern Castle Inc. (05-06-2012)
Old 05-02-2012, 09:58 PM   #8
Light Emitting Decoration
Electric_Light's Avatar
$2 for realistic watt or per ideal condition watt that you'll never get in real life?
Electric_Light is offline   Reply With Quote
Old 05-03-2012, 01:18 AM   #9
NRA Member
backstay's Avatar
Do you really know anything about solar?
Old 05-03-2012, 01:20 AM   #10
BBQ
BBQ's Avatar
I am pretty sure he is a photographer.
Old 05-03-2012, 01:27 AM   #11
NRA Member
backstay's Avatar
Panels are rated under standard test conditions (STC) at 25 C. So a panel at a lower temperature will produce more than the name plate. Where I'm at they almost always produce more. I've only had digital readouts on my system for the last 3 years, so I can't speak for the 15 years before that. But I don't think the laws of physics changed.
Old 05-04-2012, 05:13 PM   #12
Not really. If I did, I wouldn't be asking the question.
I know that a PV won't give the same output on a cloudy day as it does on a sunny day.
What I don't know is if 1000W panel can make 1,000W real life or only in laboratory conditions.
Hmmm... is it a flash reading where the panel is maintained at 25C, then taken into a bright output for a measurement before it has the chance to get hot or is it able to sustain the rated output in 25C ambient temperature?
raw performance specs for LEDs are measured like that. The chip is given a short burst, then the light output is measured.
Old 05-04-2012, 07:40 PM   #13
s.kelly's Avatar
I will be interested to hear your results. I made a solar air heater in 2010. It is far less than ideally located for visual constraints, but I still get about a 10 deg temp rise on a 100cfm fan (if I remember right) for about 4 hrs a day.
Might have 300 in it and alot of that was the fan. Fun build.
Room is discharges in is noticibly warmer than adjacent rooms when it runs.
I have seen guys run data loggers and get real data, but it seemed too much money and effort even though it would be interesting.
s.kelly is offline   Reply With Quote
Old 05-04-2012, 07:50 PM   #14
NRA Member
backstay's Avatar
To get the rating, the panel must produce at a sustained level at the 25C temp. A panel will not reach 25C if the air temp is below 40F in full sun(that's a guess on my part, someday I will do some temp checks at different temps.
Old 05-05-2012, 06:45 AM   #15
What about much above 25C?
As you know, in full sun, it will get too hot to touch even if the ambient is quite low.
Old 05-05-2012, 07:08 AM   #16
BBQ
BBQ's Avatar
Here is a random cut sheet for a PV mod. It provides what you need to calculate output at the temp of your choice. 25C is just the STC temp for comparison.
http://us.sunpowercorp.com/cs/BlobSe...ble=MungoBlobs
As far as the high temps dropping the output that is well known, that is why good design takes that into consideration. For example when the array will be flat on a roof good design will raise it up on standoffs and / or leave gaps between the panels for airflow.
We have done a ton of solar in New England and we are sure to keep doing it.
That said if there were no incentives for it there would be no reason for anyone to want to do so. Still way too much money compared to cheap grid power.
wildleg (05-05-2012)
Old 05-05-2012, 07:31 AM   #17
wildleg's Avatar
BBQ - have you done any houses, or was that all commercial ? If you have done houses, what was the largest size pv install you did for a house ?
Old 05-05-2012, 07:46 AM   #18
BBQ
BBQ's Avatar
I don't think we have done a home.
We have done systems from about 15 to 550 KW.
I was one of the first guys in the company to be doing it, it was cool at first but quickly became a bore. Worse than doing a hundred of the same fixtures because now you have to do it on a roof.
Truth be told, it made me nervous to be in charge of guys on a roof 8 hours a day for many days. It just seemed the likelihood of an accident was just a matter of time.
Old 05-05-2012, 02:29 PM   #19
So, derate 0.38% per K temp at cell above above 25C and assume 1,000W/m^3
Well, keeping 25c at the cell when ambient is likely easily above 25c and high radiant energy is not realistic without chilled water cooling.
Cars get pretty hot in the sun as you know, so I think 55C at the panel is a reasonable temperature to use.. so derate to 89% of rated output at 1,000W/m^3 of solar irradiance.
Old 05-05-2012, 03:21 PM   #20
BBQ
BBQ's Avatar
No one has said 25 is realistic operating temp in all areas. It is certainly a realistic operating temp in some areas.
It is simply a temperature to compare modules, that is all it is. Like Government fuel economy ratings.
Yes, and no one is hiding that fact. It is well covered in any PV training. OTOH on a cold winter day we can be well below 25C and well above 1,000W/m^3 irradiance.
We have not even touched on inverter losses yet ..........
Solar Panels calimurray General Electrical Discussion 25 03-19-2012 09:52 AM
Solar panels Salvatoreg02 General Electrical Discussion 1 03-11-2012 09:01 PM
solar panels help Seannorva General Electrical Discussion 22 02-11-2012 09:28 PM
Solar panels p051981 General Electrical Discussion 19 08-01-2010 04:13 PM
solar panels at Lowe's drsparky General Electrical Discussion 18 12-12-2009 11:55 AM
