Solar Cost- Residential - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
Old 04-14-2016, 03:28 AM   #1
360max's Avatar
Rewards Points: 786
Default Solar Cost- Residential
what the rough cost, broken down for mat/labor, for a 2000 sf home?
Old 04-14-2016, 05:26 AM   #2
cabletie's Avatar
Rewards Points: 102
I paid 11,300 for a 5,000 watt system on my 1800 SF home. That is material only. If I had a ranch, I would have a bigger system. My system covers 60% of my electric annually.
About a third of that was paid for by incentives. The rest paid for itself in five years.
AllWIRES and PlugsAndLights like this.
The Following 2 Users Say Thank You to cabletie For This Useful Post:
360max (04-14-2016), splatz (04-14-2016)
Old 04-14-2016, 06:39 AM   #3
motherplucker
chicken steve's Avatar
Rewards Points: 5,794
We're doing a 4000sq ft home on a mountain , $50K for poco power run 1/4 mile, 30K for solar
360max (04-14-2016)
Old 04-14-2016, 07:09 AM   #4
Lep
THE "BIG RED MACHINE"
Lep's Avatar
Rewards Points: 2,927
How many man-hours were in that installation do you think? One or two story home?
"See the ball; Hit the ball."
Pete Rose:Joe Morgan
Lep is offline   Reply With Quote
Old 04-14-2016, 08:29 AM   #5
Small Potatoes
flyboy's Avatar
Rewards Points: 402
You doing the solar Steve? What does the 30K cover? Whole Solar job or just material? How many KW?
Old 04-14-2016, 11:12 AM   #6
NRA Member
backstay's Avatar
Rewards Points: 1,480
Size of the house has no impact on solar system sizing other than available roof area. I charge $5/watt for grid tie and $10/watt for off grid. Price of M&L is about 50% Off grid parts are a little higher. These numbers are approximately.
360max likes this.
The Following 2 Users Say Thank You to backstay For This Useful Post:
360max (04-14-2016), theJcK (04-15-2016)
Old 04-14-2016, 12:23 PM   #7
cabletie's Avatar
Rewards Points: 102
Two story home. About 46 total manhours. Two six hour days with two co-workers and myself (Sat. and Sun. In the middle of August). That was to do the racking and set the panels. Probably 10 hours alone to layout the roof with a chalk line the night before, and install the inverter, SREC meter, utility disconnect and electric panel tie in.
That time does not include all the paperwork and shade analysis. I also had to draw a section view of the roof and get it stamped by a Craig's list architect. That was $300. The town would not accept my drawing unless it was stamped by an A&E.
I used Sharp panels and their racking system. I could have screwed their strut feet right to the roof. But I got their roof flange kit also. That took more time to cut the Timberline roof shingles, and slip in the flanges. I think there is 24 of them. The system sits up another 3" and supposedly gets 5% more output, because it has the airflow underneath.
I like the Sharp system. It sits tight together with an 1/8" gap between the panels. It looks clean, and has enough room for expansion from the heat.
donaldelectrician likes this.
Old 04-14-2016, 02:07 PM   #8
NRA Member
backstay's Avatar
These are REC panels and SnapNRack rails. Flashed L foot attachment.
360max (04-14-2016)
Old 04-14-2016, 04:47 PM   #9
Lep
Lep's Avatar
I have two systems to estimate. Both two-story tile roof about 5000 6000 watt. so I'm thinking maybe 50 hours total man hours ea. plus permits and drawings.
Old 04-14-2016, 04:50 PM   #10
Lep
Lep's Avatar
What was your total material cost?Not including any tax credit or anything.
Old 04-14-2016, 05:39 PM   #11
cabletie's Avatar
Rewards Points: 102
11,300 was the cost for the panels, rack, meter pan w/meter (for SREC credits in NJ) and Sunny Boy inverter w/DC disconnect. I don't remember the permit cost. The architects stamp was $300. Not sure what the rest of the materials came to.
3- 2x4x8 studs
1- 4'x4'x3/4" plywood
1- 1" roof flange
1- 1" Lb
1- 1"x12" nipple
1- 6x6x6 Nema 1 pull box (in attic under LB and top center solar panel)
30'- 3/4" EMT
5- 3/4" one hole straps
2- 3/4" set screw connectors
4- 3/4" set screw couplings
160'- #8 THHN (two strings of 12 panels)
2- 50' PV wire with MC4 ends molded on (cut in the middle to feed the strings from the JB in attic.
70'- #6 solid green THHN
20'- #10-3 romex
4- flower pots (kidding...big blue wirenuts)
1- 30A. 300V. single phase pullout disconnect
1- 25A. 2 pole Square D QO breaker
At the time an array disconnect was not required. I had a spare 3/4" EMT from my attic to the basement. I used that to get from the roof to the basement, and mounted the inverter in the basement, out of the sun. I have never heard the cooling fans turn on yet, only once when I tested them by moving the jumper on the PC board.
This is a picture of the rack with the LB through the roof flange. The roof is a 6 on 12. Doing a tile roof must be a pain in the ass.
360max and nom-board like this.
The Following User Says Thank You to cabletie For This Useful Post:
360max (04-14-2016)
Old 04-14-2016, 05:50 PM   #12
cabletie's Avatar
Rewards Points: 102
Forgot to say good luck. I know you have been pursuing solar for a while now.
Old 04-14-2016, 05:51 PM   #13
Lep
Lep's Avatar
I'm figuring $4,500 labor a two-story tile roof 6kw will be my estimate.
Old 04-14-2016, 06:29 PM   #14
cabletie's Avatar
Rewards Points: 102
Isn't that kind of low?
Like Backstay said labor is around 50% of the job. Did I read him right? It seems like that is what it is around here.
Looking at Steve's system the materials would be around $15,000. That seems about right.
Old 04-14-2016, 08:37 PM   #15
360max's Avatar
Rewards Points: 786
how much of that cost can the homeowner get 'help' with (grants, credits, etc...)?
Old 04-14-2016, 08:41 PM   #16
NRA Member
backstay's Avatar
3- 2x4x8 studs
1- 1" roof flange
1- 1" Lb
1- 1"x12" nipple
30'- 3/4" EMT
20'- #10-3 romex
Attachment 77330
I don't see a remote disconnect in your bill of materials.
Old 04-14-2016, 08:48 PM   #17
motherplucker
Nope I don't FlyBoy. ....
I'm the licensed 'spark' for a few local guru's , and to be honest i'm learning more about art 690 from them than any other source.
donaldelectrician and 360max like this.
flyboy (04-14-2016)
Old 04-15-2016, 03:21 AM   #18
Lep
Lep's Avatar
well that's why I asked you what your man hours was and you said around 45 or something. I figure 50 man hours and then plugged into somelabor rates
Old 04-15-2016, 10:29 AM   #19
NRA Member
backstay's Avatar
You said $11,300 for the "solar" part of a 5000 watt system. That's not bad. I take it you bought that from a parts company not an installer? BOS costs can vary so much you need to look at each system one on one. With rapid shut down, it can double.
Old 04-15-2016, 12:26 PM   #20
cabletie's Avatar
Rewards Points: 102
I did mine seven years ago. At the time a remote disconnect was not required. Am I right in saying a remote disconnect would shut off the DC power at the array?
I do have an AC pullout disconnect next to my utility meter. That was required by the utility. My DC disconnect is in my basement, under the inverter. At the time that was allowed. My PV wires come into the house in the attic, and are run in EMT to the basement DC disconnect. EMT was required in the house. I liked that better than seeing PVC wrap around my soffit or 12" overhang on the gable side.
The array is not fused until it gets to the DC disconnect. It comes down as two seperate strings, and is combined in the DC disconnect.
I did buy my system from a non profit organization. It is a partnership between Sharp, NECA and the IBEW. Their mission is to train and educate their contractors and employees by installing solar on their homes. They helped with all the sizing, shade analysis and rebates. They even had financing available.
http://americansolarpartners.com
360max should check them out. They are out of New York. They would know all of the incentives. I think they have an office in CA also. They may have expanded more?
chicken steve and 360max like this.
360max (04-15-2016)
Thermal Solar an Epic Bust telsa Alternative Energy Forum 16 06-15-2016 12:28 PM
Breaking into solar Anathera General Electrical Discussion 14 04-04-2016 08:29 PM
Solar interconnect issue cc2kj General Electrical Discussion 21 03-24-2016 09:06 PM
Solar and Electric AnthonyFlory NEC Code Forum 2 02-17-2016 05:53 PM
Sizing solar panels and battery bank mpetro Alternative Energy Forum 14 02-15-2016 08:55 PM
