Solar Cost- Residential - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
Old 06-16-2016, 02:06 PM   #21
Rewards Points: 88
Default usage
Originally Posted by 360max View Post
what the rough cost, broken down for mat/labor, for a 2000 sf home?
Location and demand. How many KWH do You use per Year? Where you are located use Pvwatt2 on the net to see how much you can generate.
nom-board is offline   Reply With Quote
Old 06-16-2016, 02:11 PM   #22
Rewards Points: 88
Default how much shade ?
These are REC panels and SnapNRack rails. Flashed L foot attachment.
Shade? Look that way. roof slope?
Old 06-16-2016, 03:25 PM   #23
Rewards Points: 88
You said $11,300 for the "solar" part of a 5000 watt system. That's not bad. I take it you bought that from a parts company not an installer? BOS costs can vary so much you need to look at each system one on one. With rapid shut down, it can double.
Back to the question we need to know the roof slope, shade, type of roof, He can go to pvwatt.nrel.gov and find some more information. Even in Arizona there is the high desert where evaporator cooling will work and the low desert where a person needs a heat pump or AC. No one can answer by only having the square ft. our the charge for net metering that will also be important.
wildleg likes this.
Old 06-16-2016, 03:57 PM   #24
Rewards Points: 88
Flagstaff, Phoenix, Tucson, or Benson AZ. All have Different answers. Benson has a rural electric co-op, Tucson you can still use swap cooler. but APS is not as good to deal with. Phoenix is a bit hotter so heat pumps or AC will be needed, SRP is better then APS but not the same as rural. Flagstaff you focus more on heating and can reduce the loads and it might just be better to go off grid. One size doesn't fit all.
Thermal Solar an Epic Bust telsa Alternative Energy Forum 16 06-15-2016 12:28 PM
Breaking into solar Anathera General Electrical Discussion 14 04-04-2016 08:29 PM
Solar interconnect issue cc2kj General Electrical Discussion 21 03-24-2016 09:06 PM
Solar and Electric AnthonyFlory NEC Code Forum 2 02-17-2016 05:53 PM
Sizing solar panels and battery bank mpetro Alternative Energy Forum 14 02-15-2016 08:55 PM
