Solar ROI - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
  • 1 Post By telsa
  • 1 Post By chicken steve
  • 2 Post By PlugsAndLights
  • 3 Post By 99cents
  • 3 Post By MikeFL
  • 1 Post By PlugsAndLights
  • 1 Post By ElectricMetalTuba
  • 1 Post By Navyguy
Old 03-09-2017, 06:21 AM   #1
Rewards Points: 1,624
Default Solar ROI
From another thread, figured I'd pull it out rather than hijack:
Originally Posted by Suncoast Power View Post
I think I would need about 30 or more panels 2x15 for it to give me enough ROI to make it worth it.
So, where do you hop on?
It's going to take 10 years to pay off and with that, the efficiency of the panels will increase.
I am just curious. Whenever I see the ROI calculations from the solar sales people, they assume that once it's in it's basically zero maintenance and lasts forever.
Did they figure in the life span of the inverter for you? I don't know how expensive the ones they use for solar but IME even good ones don't last forever.
Are the panels supposed to be permanent and maintenance free? Outside of wind damage etc.
telsa (03-09-2017)
Old 03-09-2017, 06:28 AM   #2
Rewards Points: 12,430
My 'beef' with PV: it needs to be installed where local conditions are IDEAL.
That means, pretty much, New Mexico.
Ideal weather, ideal climate... a Davis Bacon install. ( TVA, BPA scale projects )
Roof top PV is a sci-fi fantasy.
Too many roof falls.
Too many roof leaks.
Economically, PV power 'blew up Europe.'
{ It bankrupted Spain... and put a huge hole in Germany's finances. }
{ The Spanish government contracted for PV power -- at $0.58 per kWHr. (!!!!!)
{Wholesale.}
This bleeding brought down the government, and the nation.
Don Quixote, indeed.
splatz (03-09-2017)
Old 03-09-2017, 06:29 AM   #3
motherplucker
chicken steve's Avatar
Rewards Points: 4,302
One huge ROI factor is what local poco's grant $KWH net metering.
IIRC, legislation passed some 40 yrs ago stating they had to buy back, yet set no %.....
splatz (03-09-2017)
Old 03-09-2017, 06:51 AM   #4
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,218
Web search produced this:
What Is the Lifespan of a Solar Panel? Photovoltaic (PV) modules typically come with 20 year warranties that guarantee that the panels will produce at least 80% of the rated power after 20 years of use. The general rule of thumb is that panels will degrade by about 1% each year.Apr 20, 2014
And this:
A solar PV system is said to have a lifespan of around 25 years. However, same is not the case with the solar inverters. Most inverters come with a life-expectancy of ten years. Although the estimated lifespan of solar inverters is ten years, there are cases where inverters have lasted for 20 years or more. Most inverters require regular maintenance in order to ensure that they are working efficiently; inverters sometimes do require repair. Any malfunctioning of the inverters can cause complete shutdown of the PV system. When that happens, neither usable power is generated nor is there any return on customer investment. Inverters typically get replaced after ten years, and the replacements costs can be significant – sometimes up to 10% of the total capital cost for the project. Factors Affecting the Lifespan of Inverters A PV inverter comprises of passive components like capacitors, inductors and also electromechanical devices like relays and switches. They are complex, mechanical devices which comprise the major portion of maintenance expenditure related to PV systems. They are prone to environmental stressors irrespective of whether they are located indoors or outdoors. Several factors can affect the life of inverters. High ambient temperatures deter the performance of inverters. Hence care should be taken regarding the positioning of inverters. Moreover voltage fluctuations and low grid power quality can adversely affect the life span of inverters. To increase the longevity of inverters, it should be ensured that they remain clean and do not overheat. A quarterly inspection no them for visual signs of damage and to verify that the air and fan grills are free from dirt can make a difference to the life expectancy of inverters. Subscribe to FREE Solar Mango Newsletter - News and Opinions on Implementing Solar
Read more at: http://www.solarmango.com/ask/2015/0...lar-inverters/
chicken steve and splatz like this.
splatz (03-09-2017)
Old 03-09-2017, 07:38 AM   #5
Rewards Points: 7,116
It's -24 here this morning. I'm content to be hooked up to dependable natural gas and power. No solar BS for me.
HackWork, daveEM and splatz like this.
Old 03-10-2017, 09:46 AM   #6
MikeFL's Avatar
Rewards Points: 762
Send a message via Skype™ to MikeFL
First thing that comes to my mind is how much it's going to cost to reroof the building with all that solar equipment up there.
HackWork, telsa and splatz like this.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
Old 03-12-2017, 09:25 AM   #7
Rewards Points: 540
One of the topics that I never really hear about when determining the ROI for solar is the actual cost of electricity being purchased. Everybody always seems to talk about the generation side, but never talks about the “offset”. So in a place like Ontario where energy costs (specifically electricity) are a big issue, they may be more desire to offset costs (net metering) vice generate (MicroFIT) and sell back to the utility. Now a place like Quebec, electricity is far less expensive then Ontario, so the offset option may not be as attractive.
Cheers
John
Datawise Solutions Inc
Old 03-12-2017, 10:09 AM   #8
Safety Pin Member
So this is only anecdotal, so take it for what it's worth: Guy I know owns
a kitchen cupboard fabricate/install company. He says he has 4 houses
each with 10kW solar (I've seen the one on the house he lives in). Says
they each cost between $22 and $30K and the payout is $5 to $10K per
year, per system. Microfit program here in Ontario pays much more for
generation than consumers pay. The amount they're paying has been
dropping since microfit was introduced. Atleast one of his houses is on
one of the earliest rates, which will be in effect for 20yrs.
P&L
Navyguy likes this.
Old 03-12-2017, 03:37 PM   #9
motherplucker
If the market here was legislated to pay out more for generation than usage, i'd definitely have more interest in the NABCEP Plugs....
PlugsAndLights likes this.
Old 03-12-2017, 08:04 PM   #10
year, per system
P&L
So you're talking subsidies, then ?
Old 03-20-2017, 01:34 PM   #11
ElectricMetalTuba's Avatar
Rewards Points: 86
In Alberta, Canada this month, they are rolling out 30% rebate on residential solar installations. So home owner buys panels and they get Provincial funding for 30% up to 11,000$. The catch is they require you to have a certified electrician do the tie in.
Commercial is around 25%.
ElectricMetalTuba is offline   Reply With Quote
Old 03-20-2017, 02:04 PM   #12
Safety Pin Member
Related question: Gather that an engineer of some sort needs to sign off
on structures ability to support the load. Anyone know more about this?
Wondering about typical price, whether most places pass w/o upgrading,
if all NA jurisdictions require this, and any direct experience with this part
of it.
P&L
Old 03-20-2017, 04:09 PM   #13
Rewards Points: 86
You don't need engineer unless Its high wind/high snow. Most distributors have dead load calculators for their assembled products.
Old 03-20-2017, 05:25 PM   #14
Rewards Points: 540
of it.
P&L
My experience is that this is insurance driven and not CBC or OBC driven. The weight of a typical 10Kw MicroFIT is less then a layer of standard shingles. While there is a potential issue with shear I have not come across it yet. Most residential clients send the specs to their insurance companies and unless they ask for something it is a non-issue.
Cheers
John
Solar light box JesseButlerPREC Alternative Energy Forum 1 03-02-2017 07:03 AM
DC solar system for a single sign light dham206 General Electrical Discussion 35 02-12-2017 06:42 PM
Solar Technology Mandatory For New Construction? Cricket General Electrical Discussion 10 06-13-2016 11:38 PM
Solar Scammers Nom Deplume General Electrical Discussion 4 05-11-2016 06:49 AM
Sizing solar panels and battery bank mpetro Alternative Energy Forum 14 02-15-2016 08:55 PM
