Old 07-29-2012, 11:13 AM   #1
Swimmer
swimmer's Avatar
Default #10 XLPE 125C Wire Ampacity?
I'm installing a 40A electric range and the wires in the appliance whip (attached to the range) are #10 XLPE 125C.
I can't find XLPE in the 2008 NEC though several posts on this site indicate I should see it 310.15 - 310.21 tables. I googled XLPE and it looks like it is used in automobiles.
Table 310.16 says various #10 wires rated at 90C are good for 40A but I don't see XLPE in the wire type heading.
Do I need to replace this whip with #8 wire or am I good to go?
Thanks
Elvis is in the building
Old 07-29-2012, 11:16 AM   #2
BBQ
BBQ's Avatar
If it is a UL listed range cord the NEC does not apply and you are free to use it.
BBQ is online now   Reply With Quote
Old 07-29-2012, 11:17 AM   #3
Electric Al
oldtimer's Avatar
Thanks
I M O, if the equipment came complete, and is UL or (in my case CSA) approved. Then you should be good to go.
I'd rather have a bottle in front of me , than a frontal lobotomy. ( Quote from Tom Waits. )
Old 07-29-2012, 12:48 PM   #4
Swimmer
swimmer's Avatar
The range had been returned to Sears and re-sold at discount. Besides this, it is new.
Proper flex connector was missing from the conduit and ground and neutral were crimped together. This makes me question the wire size. It's no problem for me to attach a #8 whip but I'd like to know about this XLPE 125C business as this may be something I'll encounter in the future.
Old 07-29-2012, 01:19 PM   #5
Sideways Sparky
farlsincharge's Avatar
It stands for cross linked polyethylene. Very common up here. Don't overthink it too much.
farlsincharge is offline   Reply With Quote
Tags
125c, xlpe ampacity
Xlpe/use TheBrushMan007 NEC Code Forum 11 04-14-2011 02:02 PM
240.4B2 breakered above wire ampacity??? 1capybara NEC Code Forum 20 01-08-2011 02:57 PM
Installation Rate/Pulling Rate for Single 630mm2 76/132Kv XLPE/SWA custy General Electrical Discussion 0 01-25-2010 01:42 AM
metric sized wire & ampacity chart BryanMD UK Electrical Forum 6 12-08-2008 03:00 PM
What is the ampacity for 8 AWG wire? 50 or 40 gilamor NEC Code Forum 23 10-19-2008 09:28 PM
