Old 11-30-2011, 11:23 PM   #1
Chief Electron Relocator
Default 2011 NEC update for Iowa
Just a note to all Iowa electricians: The IEEB has adopted the 2011 NEC, effective 1/1/2012. Only one amendment has been made: The language of 210.8 has been deleted and replaced with the 2005 210.8 language (specifically, this affects garages and basements).
The adoption covers the entire state, whether the work is performed where the IEEB will inspect the work, or any local jurisdiction that still maintains it's own inspections.
Local jurisdictions will be able to make amendments on their own, but they must:
1. Result in a requirement stricter than the 2011 NEC,
2. Be approved & adopted by the Jurisdiction, and
3. These amendments filed with the IEEB.
den (12-01-2011)
Old 12-01-2011, 07:40 PM   #2
mbednarik's Avatar
I'm glad they are keeping the old wording with the gfi's. Although i got dinged in ames because they adopted 08 as written, wasn't thinking about it and a put in a simplex for the sump pump, i geuss they like their basements to flood.
mbednarik is online now   Reply With Quote
Old 03-25-2012, 10:25 AM   #3
Default what code year is being used in Virginia in 2012??
can someone please tell me which code year is being used in Virginia as of 2012??
rdill is offline   Reply With Quote
Old 03-25-2012, 10:45 AM   #4
Contact whoever issues your license.
Old 03-25-2012, 12:36 PM   #5
I got mine at Walmart and that guy had no clue. Now what?
Check here
http://www.nema.org/stds/fieldreps/codealerts/
Brian John
Leesburg, VA
Old 03-28-2012, 08:46 PM   #6
Default Virginia
Virginia is on the 2008 code, but is accepting continuing education on the 2011 code. Not sure what the inspectors are looking for.
http://go.bluevolt.com/default/Catal...ducation/4186/
Sangi96Elec is offline   Reply With Quote
How to Post Photos & Images : 2011 Update 480sparky Site Help and Suggestions 19 09-21-2012 07:42 PM
Iowa (480) ET Eux. Little-Lectric NEC Code Forum 4 09-27-2011 09:37 AM
2011 Code Update class Wirenuting NEC Code Forum 0 06-02-2011 08:24 PM
New here, From Iowa. IaElectrician70 Introductions 7 05-01-2009 10:21 PM
Hello From Iowa jculber Introductions 6 04-23-2008 07:41 PM
