Old 04-03-2010, 09:53 AM   #1
Default 210.52(E) outdoor rec
So technically is this to code? (just on a kick lately-review time ya know) never gave this much thought.
1 and 2 family homes,you need an outside rec,ACCESSIBLE While STANDING at grade level.
you have the front door,and a 8' porch. The rec is placed to the left of the door.
Does this meet the requirement?
Old 04-03-2010, 10:01 AM   #2
Chief Electron Relocator
Uh, is the recep accessible?
Old 04-03-2010, 10:06 AM   #3
Sure for people with 8' arms.
Old 04-03-2010, 10:10 AM   #4
Is the recep. accessible from grade level-- not the deck-?
When you say "8' deck" I am assuming you are not talking about the height off grade.
If you can stand on grade and plug a cord into the recep. and it's not over 6'6" above grade, then you are good to go-- of course, this could be interpreted differently depending on the inspector.
Old 04-03-2010, 10:14 AM   #5
Standard front porch,8' deep,nice railings and posts.
Old 04-03-2010, 10:15 AM   #6
Betcha it looks nice from the street. So where is the recep located?
Old 04-03-2010, 10:17 AM   #7
william1978's Avatar
I would say no. I don't think you would be able to reach it from grade. I have seen rec placed so that it will take care of the rec on the porch and the one accessible from grade.
Old 04-03-2010, 10:17 AM   #8
Yes it does,and the Irisis are starting to bud.
Rec just to the left of the door,so one can plug in a radio or something.
Old 04-03-2010, 10:38 AM   #9
Left of the door. Check.
How high off the floor?
Old 04-03-2010, 10:46 AM   #10
18"-
Old 04-03-2010, 10:47 AM   #11
That is a great convenience receptacle but it does not appear the recep. will fulfill the requirements of 210.52(E).
Remember grade is grade level not deck level. If you can stand on grade and plug it in then you are probably good to go.
Old 04-03-2010, 10:53 AM   #12
So porches and decks aren't 'grade levels'? "Grade" only applies to dirt and grass?
What about driveways and sidewalks? If my POCO cash register is required to be 4-6' 'above grade', I can't install it over a sidewalk or driveway because there's no dirt to stand on?
Suppose there's a 6x6 PVC box buried under the grass (no dirt, just grass!)? Is that 'grade'? 6c6 PVC boxes can't be buried below exterior receps because that would cause the recep to fall outside the requirement of 510.52(E)?
Sorry, I'll say the front porch floor, regardless of the material it's made of, is grade.
Old 04-03-2010, 11:00 AM   #13
Licensed Journeyman
nolabama's Avatar
We use 480's description of grade to justify raised meter heights and raised switch heights for services in flood prone area's 'round here. My question would be is the deck under the outlet, not dirt/aka grade? If so it is compliant.
Old 04-03-2010, 11:02 AM   #14
You are certainly free to disagree but that has long been the interpretation around here. I have never seen a landscape plan or any other plan that references decks as grade.
Correct me if I am wrong Ken but wasn't there a time when the outdoor recep was permitted from a deck as long as there was direct access to grade from the deck, ie, stairs.
The NEC 2008 has specifically added the words accessible while standing at grade level-- fwiw---
Old 04-03-2010, 11:21 AM   #15
Here is another question for you. If you interpret that the deck is grade then when you measure the 6'6" from grade you are measuring from the deck.
Okay now the deck is 7' off grade with no stair access to ground (what I call grade). In this scenario you would allow the recep on the deck at 18" above the deck boards as satisfying 210.52(E)? I don't see it. If deck is grade, IMO you would have to accept the above scenario.
Old 04-03-2010, 01:45 PM   #16
What if the the house is built on pillars on a lake? Is the water grade? The intent of the code was to make sure there is a receptacle near the door. Someone chose the wrong terminology, it was approved, and now people are putting pvc boxes under sod.
knowshorts is online now   Reply With Quote
Old 04-03-2010, 01:48 PM   #17
Fried Bologna um um good!
jwjrw's Avatar
Aren't you now required in 2008 to have one on the deck AND one reachable from grade level also? Which if you are able to reach it from the ground should meet both codes.
Old 04-03-2010, 02:03 PM   #18
In general, you are required to have one on a deck.
210.52(E)(3) Balconies, Decks, and Porches. Balconies, decks, and porches that are accessible from inside the dwelling unit shall have at least one receptacle outlet installed within the perimeter of the balcony, deck, or porch. The receptacle shall not be located more than 2.0 m (6½ ft) above the balcony, deck, or porch surface.
Exception to (3): Balconies, decks, or porches with a usable area of less than 1.86 m2 (20 ft2) are not required to have a receptacle installed.
The argument is, simply put, what is considered grade? The deck or the ground underneath it.
Old 04-03-2010, 02:05 PM   #19
I disagree. Where did you get the intent from? Can you substantiate that claim? 210.52(E) does not state by a door but on a deck. Why would you need it to be by the door? That is often a bad spot IMO.
Old 04-03-2010, 02:09 PM   #20
jwjrw's Avatar
I say grade is ground level(dirt). A deck is ABOVE grade. Always has been here. I believe the new deck requirement is in addition to the regular outside receps.
Outdoor Panels mmiller9 Services and Service Equipment 17 12-22-2009 07:28 PM
Outdoor plugs drm General Electrical Discussion 8 11-14-2009 01:38 PM
Outdoor E-stop heel600 General Electrical Discussion 6 03-26-2009 11:28 PM
Small 12-24 for outdoor JamesINla Services and Service Equipment 3 11-18-2008 12:10 AM
Outdoor Hot Tub/Spa Install Reseman General Electrical Discussion 2 06-14-2008 08:54 AM
