Old 04-04-2007, 06:01 AM   #1
Default 80' Tap Rule
Pictures could not do justice what I just ran across on a job site. We had a facility where the chiller disconnect (fusible) stationary/movable contacts had a thermal issue and the disconnect needed to be replaced. Went to the job and found the parallel 500 kcmils were bus tapped from a 4000 amp switchboard, conductor length approximately 80 feet. Can't seem to locate that rule in Article 240. CAN ANYONE HELP?
Old 04-04-2007, 05:35 PM   #2
Eh, 10, 20, 80, whatever...
Holy smokes.
Old 04-08-2007, 08:15 AM   #3
Pierre Belarge's Avatar
The bus tap, was it before the main service disconnect(s) or after the Main service disconnect(s)?
Pierre Belarge is offline   Reply With Quote
Old 04-08-2007, 05:59 PM   #4
On the load side of a 4000 amp GE HPC fused switch, with GFP.
Is there a "rule of thumb" for going to a 480V service instead of a 208V? bbaumer General Electrical Discussion 6 04-05-2008 11:12 AM
6 disconnect rule... oops! MDShunk Services and Service Equipment 14 10-23-2007 04:35 PM
AFCI rule in 2008 NEC, 210.12(B) Joe Tedesco NEC Code Forum 52 08-30-2007 10:24 AM
