Old 04-05-2010, 05:18 PM   #1
Fried Bologna um um good!
jwjrw's Avatar
Default adding lights to a 2 wire circuit
I think I know the correct answer but Ill put it out there anyway. Kitchen light fed with a 2 wire no ground. Customer wants to remove light and add 4 can lights. Can I add them or do I have to pull a ground wire or a new circuit to it? Code ref???
Old 04-05-2010, 05:21 PM   #2
Chief Electron Relocator
410.40 pretty much hoses you.
Old 04-05-2010, 05:30 PM   #3
jwjrw's Avatar
What is the code art that allows you to run a seperate ground? Would that apply to what I have?
Old 04-05-2010, 05:41 PM   #4
300.3 (b)(2).
Gamit (04-05-2010), jwjrw (04-05-2010)
Old 04-05-2010, 05:58 PM   #5
jwjrw's Avatar
Thanks 480!
Old 04-08-2010, 01:16 AM   #6
I saw a guy do it once.
SparkYZ's Avatar
In all honesty, (call me a hack!), if I'm tapping into a metal j-box, that is flexxed in, Ill just drill and tap a ground screw hole in the box, and loop my ground wire around that screw.
SparkYZ is offline   Reply With Quote
Old 04-08-2010, 09:40 AM   #7
william1978's Avatar
You can't extend that old cir. without it having a ground. From what you have already posted I think you already know that, but just passing it along.
Old 04-08-2010, 09:43 AM   #8
What's hack about it? As long as two threads make contact with the box, you're golden!
Old 04-08-2010, 12:01 PM   #9
SparkYZ's Avatar
The fact that steel flex is not and was not an approved EGC. It works as one yeah but its not approved
Old 04-08-2010, 12:44 PM   #10
You sure? Check 250.118
Old 04-08-2010, 02:09 PM   #11
jwjrw's Avatar
I was talking about 2 wire romex in a metal box. I knew it had to be grounded but wanted to make sure. The panel is in a kitchen cabinet and will be hard to get a new circuit out of. Oh well it is what it is.
Old 04-08-2010, 07:15 PM   #12
SparkYZ's Avatar
A proper fitting for grounding, would that be the older styled set screw flex connectors? Do the screw in ones work? And I'm sure these flex runs are more than 6'.
Old 04-08-2010, 07:20 PM   #13
As long as the conn. are listed for grounding they should be fine. I agree with you the runs are probably longer than 6'.
Old 04-08-2010, 07:34 PM   #14
zen
zen's Avatar
the most important thing i have learned on this web site is to do whats right even if the code doesn't make you,,,and providing a proper ground in a way that meets or exceeds the code is all you can do...
I can break an unbreakable plate,,,yes i can,,,
zen is offline   Reply With Quote
Old 04-09-2010, 06:34 AM   #15
jwjrw's Avatar
So does a PROPER ground mean you use a self tapper?
I agree.
Old 04-09-2010, 11:08 AM   #16
bauler's Avatar
Ok, what do you do if the house is wired in old 2 wire romex and the customer wants to add a light to a circuit? Or flex, how far
back do you go? So now one set of lights in the house is grounded per code.
I have one of those now. Bath remodel, existing wired with flex, no ground. The bath I'm completely re-wiring with NM, taking homeruns back to the panel, but what about the other 10 circuits coming out of the panel? I just explained the code to the customer, and let them make the call.
bauler is offline   Reply With Quote
Old 04-09-2010, 11:58 AM   #17
jwjrw's Avatar
The other 10 are "grandfathered" in and can stay. But if you add lights you either run a ground to them or pull new cicruits with a ground.
Old 04-09-2010, 12:01 PM   #18
Yep.
The Following User Says Thank You to william1978 For This Useful Post:
jwjrw (04-09-2010)
Old 04-09-2010, 03:24 PM   #19
bauler's Avatar
Thumbs up
Yea, thats what I'm doing. But by explaining the problem to the customer I'm getting more work to replace some of the old wiring that is easliy accessible .
The big question I have is what to do as asked above. You have an old 2 wire system and the customer wants to add a light. Is that grandfathered in? I know outlets you can just use a GFI plug, but lights???
Old 04-09-2010, 03:26 PM   #20
jwjrw's Avatar
You have to run a seperate ground wire or pull a new homerun. Or put up a plastic fixture.
3way circuit with LED lights Geno52 Residential Electrical Forum 20 09-23-2009 03:58 PM
Security camera cable & wire next to 14g wire for outdoor lights agent99 Structured Wiring 5 09-17-2009 04:36 PM
Adding circuit to old flush mounted panel, what connector? Jeff000 General Electrical Discussion 43 06-08-2009 07:02 PM
Adding A Submain Gavin Adams UK Electrical Forum 4 08-31-2008 04:31 PM
No earth wire in lighting circuit????? wattsyboy Other Codes and Standards 1 06-18-2007 09:52 PM
