adding neutral bar - Electrician Talk - Professional Electrical Contractors Forum
Old 06-15-2013, 09:41 PM   #1
Journeyman
Default adding neutral bar
If you add a neutral bar to a service entrance panel, can you directly attach it to the case as long as you have an appropriately sized jumper? I have always done it this way but just wanted opinions on it.
P-Electrician is offline   Reply With Quote
Old 06-15-2013, 10:27 PM   #2
ET rocks
3xdad's Avatar
Rewards Points: 2,174
Sure. As long as you install it per the bars instructions (drill and tap using the supplied screws).
Not some nasty hack job.
Too soon, Black Dog... way too soon...Rock on buddy.
3xdad is offline   Reply With Quote
Old 06-15-2013, 10:47 PM   #3
Journeyman
I used self tappers, did not have any screws supplied, panel is a train wreck old sq d qo
Old 06-16-2013, 01:50 AM   #4
ET rocks
3xdad's Avatar
Like sheet metal screws? If so, that's a no go.
Get some Square D PK kits and keep them in your tool bag.
Old 06-16-2013, 01:58 AM   #5
Journeyman
I have to go back to do some other work so i will pull them out and drill/tap the holes. Thank you
Old 06-16-2013, 02:26 AM   #6
Deep Cover's Avatar
Rewards Points: 2,024
You cannot do what you describe if there is a main before this panel.
Deep Cover is offline   Reply With Quote
Old 06-16-2013, 02:29 AM   #7
Journeyman
Main breaker is in the panel. Is not a 4 wire feed
Old 06-16-2013, 02:34 AM   #8
Deep Cover's Avatar
Just because there is a main breaker in the panel and there aren't 4 conductors entering the panel, does not necessarily mean that this is the main panel.
It very well may be, but from what I've read on this site, meter/main combo's are pretty common on the east coast.
Old 06-16-2013, 02:40 AM   #9
Journeyman
No oc device in the meter
Old 06-16-2013, 03:57 AM   #10
BBQ
Salty Member
BBQ's Avatar
Not in MA, RI or CT.
Old 06-16-2013, 09:05 AM   #11
ITW
In order to have a ground bar mounted without insulator bases to the panel enclosure that panel must contain the service disconnect switch. That means the enclosure must contain the first means of disconnect for the service entrance conductors to that facility. The grounding and grounded systems cannot come together at any other place than the service disconnect enclosure described here.
ITW is offline   Reply With Quote
Old 06-16-2013, 09:07 AM   #12
ITW
Exclamation
I was thinking neutral bar... a ground bar can be mounted to the enclosure.
Old 06-16-2013, 09:12 AM   #13
ITW
Talking
...and should be.
Old 06-16-2013, 09:17 AM   #14
ITW
A neutral bar can only be bonded to the enclosure at the first means of disconnect for the service entrance conductors.
Seems rather round-about, but if you think on this some it will come to full light for you.
Old 06-16-2013, 09:35 AM   #15
Professional Nit Picker
manchestersparky's Avatar
Rewards Points: 1,568
Not in Md, DC, or southeastern Pa
Anything Worth Doing ....
Is Worth Doing Right
Old 06-16-2013, 09:42 AM   #16
8V71's Avatar
Rewards Points: 2,900
Probably an unanswerable question but any ideas why?
8V71 is offline   Reply With Quote
Old 06-16-2013, 12:06 PM   #17
ET rocks
3xdad's Avatar
Hmmm. In post #1 the OP mentions "service entrance panel".
What's all the doubt for?
Old 06-16-2013, 12:12 PM   #18
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 258
Unless the bar came with instructions that required machine-screws, I don't see a problem with OPs installation.
The screws are for mounting, not carrying fault current like they would be with a ground bar. As long as the jumper wire to the service neutral is in place, it seems compliant.
Old 06-16-2013, 12:13 PM   #19
BBQ
Salty Member
BBQ's Avatar
I am really wondering what is going on that he needs to add a neutral bar.
Old 06-16-2013, 12:17 PM   #20
Speaking about ground bars... How many ground lugs have you bolted to the side/bottom of a panel thru a 1/4" hole that you drilled yourself?
Hackster is offline   Reply With Quote
Adding a/c XxZavyxX Residential Electrical Forum 12 05-24-2013 09:28 AM
not adding up well..... chicken steve Off Topic (Non Trade) 36 08-21-2012 09:32 PM
adding #4 lug to neutral buss billyrr Residential Electrical Forum 27 12-01-2011 07:14 PM
Broken Neutral, Connect Neutral to Box? JayWater General Electrical Discussion 45 08-19-2011 09:02 PM
one leg 130v to neutral the other 117v to neutral??? brooklyn General Electrical Discussion 3 01-07-2010 08:59 PM
