Old 08-10-2010, 08:44 AM   #1
Default arc flash breaker code
hello,
I performed a search here and didn't find what I was looking for, so here goes...
I've looked at the code when it comes to using the AFCI breakers...I've been told that each room is to have a dedicated circuit protected by the AFCI, however, I don't get that from the code sections regarding AFCI protection...it states that certain rooms need to be protected, but no where does it state that each bedroom needs to have its own home run...
I'm about to rough a 2 family dwelling, the rooms are so small and only have 3-4 receptacles per room, so I can't imagine running a home run for each room...a retired inspector told me each one had to be a home run...but that's not what the code book says...
anyone have any clarification on this?
am I just reading the code wrong?
maybe I missed something...
480jc is offline   Reply With Quote
Old 08-10-2010, 11:29 AM   #2
Ax grinder
raider1's Avatar
There is nothing in the NEC that requires each bedroom to be supplied with an individual branch circuit.
Chris
Old 08-10-2010, 12:17 PM   #3
TheRick's Avatar
There is nothing that requires an individual branch circuit for each bedroom.......but each branch circuit that serves bedrooms shall have AFCI protection for the entire branch circuit.
Rick -
Old 08-11-2010, 07:33 PM   #4
Default that's what I thought
yeah,
that's what I thought...I just figured I'd ask, sometimes we don't see things that others do...thanks for your help Gents!
Old 08-11-2010, 07:38 PM   #5
Originally Posted by 480jc View Post
hello,
Arc Flash...Arc Fault...It stumbles me, as well. But we knew what you meant.
Old 08-11-2010, 08:04 PM   #6
Electric Al
oldtimer's Avatar
Depending on the number of receptacles on the cct.
Old 08-11-2010, 08:07 PM   #7
Chief Electron Relocator
Huh?
Old 08-11-2010, 08:19 PM   #8
Electric Al
oldtimer's Avatar
Huh?
I mean, however many receptacles are allowed on each circuit.
Old 08-11-2010, 08:20 PM   #9
In a dwelling, there is no limit.
Old 08-11-2010, 08:28 PM   #10
Electric Al
oldtimer's Avatar
Are you saying, that by your code, you can put as many receptacles as you want, on the same circuit? Or, are you yanking the oldtimers chain?
Old 08-11-2010, 08:29 PM   #11
He said there is no limit...He didn't say it was CODE.
Old 08-11-2010, 08:31 PM   #12
Send a message via Yahoo to doubleoh7
In a dwelling unit, there is no max. # of receptacles per circuit.
doubleoh7 is offline   Reply With Quote
Old 08-11-2010, 08:35 PM   #13
Electric Al
oldtimer's Avatar
WOW. You could wire an entire house with a 12 cct. loadcentre.
Old 08-11-2010, 09:12 PM   #14
Technically, five.
Old 08-11-2010, 09:55 PM   #15
Send a message via Yahoo to gold
hello,
What is your electrical related field/trade: journeyman electrician/licensed electrical contractor
I call BS.
Call an Electrician.
gold is offline   Reply With Quote
Arc Flash equipment garfield General Electrical Discussion 10 03-07-2010 11:11 PM
What is the flash of arc flash? Jeff000 General Electrical Discussion 26 10-31-2009 09:20 PM
Arc Flash RIVETER General Electrical Discussion 21 10-28-2009 07:33 PM
Flash Lights brian john Tools, Equipment and New Products 49 10-26-2008 09:33 AM
Arc Flash K&R Workplace Safety 2 03-10-2007 08:07 AM
