10-12-2009, 03:01 PM
Bathroom w/ Door Separating Sinks From Toilet
Would a bathroom like this require GFCI protection at all?
The NEC 2008 Handbook says yes. (On the page of 210.8 (B).)
I couldn't find a source for this
A "bathroom" is defined in 100,Part I as "an area including a basin with one or more of the following; a toilet, a tub, or a shower"
This bathroom, however does not have a basin in the same "area" as a toilet, tub or shower.
Can anyone find a reason this would require GFCI protection?
10-12-2009, 03:11 PM
Water and electricity don't mix?
That would be reason enough for me.
First time razor falls into the sink would justify it.
I ran the lighting on a GFI too.
 Don't fight .. Play nice!
10-12-2009, 03:17 PM
Hey, I'm with you, no question common sense tells you this needs GFCI protection, the question is, is it NEC required or not.
The Handbook says yes. Is there a source?
10-12-2009, 03:31 PM
Mad Skills
Are you doubting whether or not the image in the picture is an "area"?
10-12-2009, 03:40 PM
That's right. If a door doesn't close an area what does.
Maybe the outlets right outside every bathroom are considered in the bathroom? Of course not, theres a door it's a separate room.
10-12-2009, 03:43 PM
Bath area
I agree with all of the responses to this question,so far. The bath room is a generic term for Bathroom, Washroom, Dump-room, or what have you. It only makes sense that if you have a sink there and a receptacle, it should have GFCI protection.
Another problem I have seen, a lot, is not paying attention to the correct polarity when installing the light fixtures.
10-12-2009, 03:50 PM
Sorry bathroom is not a generic term, it is defined by NEC article 100 as "an area including a basin with one or more of the following; a toilet, a tub, or a shower"
not what have you.
10-12-2009, 03:51 PM
Mad Skills
Ok...so what word/s would you use to describe these "rooms"?
Extra points in you use NEC terminology
10-12-2009, 04:13 PM
Seen your member
I'd say most likely it's going to be considered a bathroom. Door or no door.
10-12-2009, 04:17 PM
Bath room
Ok, I know you are correct. But the intention of the code is that IF, you have a receptacle in that area close to a sink or basin it is cheaper to GFCI protect it than to buy and frame a door to get out of the requirement.
P.S. I hope you have a sense of humor...And the original question, in fact, was a good one.
10-12-2009, 04:22 PM
Seen your member
Ok, I know you are correct. But the intention of the code is that IF, you have a receptacle in that area close to a sink or basin it is cheaper to GFCI protect it than to buy and frame a door to get out of the requirement............
The Code could care less which is cheaper.
10-12-2009, 04:58 PM
Not Banned Yet
maybe you don't know what a "basin" is.
all the other stuff comes AFTER the presence of the basin; so yes GFI.
March 2010: On the road with my RV. California is first primary destination then it is off to Eastern OR, Northern ID and Western MT for drycamping and fly fishing until Labor Day.
10-12-2009, 09:21 PM
Mad Skills
So if we put a recept. where the tub/toilet is [in OP's 1st post] ....then no GFCI protection required ?
10-12-2009, 09:41 PM
Not Banned Yet
Not saying I'd want to be the one to fight it with the ahj...
but as per the code language...if there is no basin.... yeah no gfi either.
re the ahj :
much simpler to just feed that recept downstream of the gfi at the lav
10-13-2009, 12:11 AM
Mad Skills
re the ahj :
Code language says "area"....IMHO, the area begins as you exit the last defined area...be it a hallway, bedroom, kitchen, etc.
10-13-2009, 07:37 AM
That sounds like a very nice distinction, but is that definition backed up by anything?
10-13-2009, 09:28 AM
Not Banned Yet
as in the last thread on the areas where the SA 20A circuits apply.
you could also say that the toilet and tub are also basins.
the rule affecting comm'l bathrooms may come into play too.
You don't have to install a recep., but if you do it better be GFI protected.
10-13-2009, 09:50 AM
#18
The NEC obviously does not consider toilets or tubs to be basins from the wording of the bathroom definition: "an area including a basin with one or more of the following; a toilet, a tub, or a shower". If it considered them basins it could have just said two basins.
10-13-2009, 10:12 AM
#19
Not Banned Yet
your grasping at straws dude.
everyone likes to play devils advocate in these as a mental exercise and some are genuinely confused... but don't confuse that with suggesting extreme interpretations are the route to "correctness".
The NEC is about the lowest common denominator. It has to be.
On that basis then... "area" includes the space in proximity to X which has installed fixtures commonly and ordinarily associated to X; regardless of how fancy the "architect" may be with their design.
KISS. Live by it. You'll sleep better.
10-13-2009, 10:49 AM
#20
What is a basin?
BryanMD is correct. The argument is all about what a basin is..."a bowl-shaped vessel usually used for holding liguids, or food."
There are vessels in both rooms...If there is a receptacle in either room, it must be GFCI protected.
RIVETER
