Old 10-25-2009, 07:21 AM   #1
Default built in disconnects
Do you guys find that most new - ac units , condensing units as well as heaters are coming with built in means of disconnects
lakeveiw is offline   Reply With Quote
Old 10-25-2009, 07:52 AM   #2
Ratus Maximumus
Bob Badger's Avatar
It depends on the job and how the units are ordered. The built in disconnects are an option when the units are ordered.
Many of the large chain stores we do will have job specs that require the HVAC contractor to order units with built in in disconnects and built in GFCI service outlets. Makes it sweet for us, we just bring a single 480 volt feeder to them and we are done. The GFCI receptacle is powered from the 480 via a transformer.
Bob Badger
Electrical Construction and Maintenance
MA, RI, CT
Old 10-25-2009, 10:09 AM   #3
I am a RAT.
william1978's Avatar
I have seen that also. It sure makes it a lot easier on the electrician for sure, and like you said Bob it is becoming more and more common.
Old 10-25-2009, 10:29 AM   #4
Not much around here. The option for the breaker on an average residential job adds over $100.00 Most HVAC contractors won't spring for that, just to save the electrician a $6.00 pullout. I agree,,,it's nice, but in the game of money, it doesn't add up.
Old 10-25-2009, 11:16 AM   #5
Did 2 rooftop units last week and they both came with built in disconnects. Nice and easy.
Loose Neutral is offline   Reply With Quote
Old 10-25-2009, 09:19 PM   #6
JohnJ0906's Avatar
Commercial, yes.
Residential, no, at least as far as A/C and heat pump units. Air handlers/furnaces, sometimes.
John from Baltimore
"One day at a Time"
Old 10-25-2009, 09:43 PM   #7
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
You dont hook it up? Doesnt an HVAC company have to have an electrical lisence to hook it up in that case?
~Matt
Old 10-25-2009, 10:30 PM   #8
Rat in a Dress
BCSparkyGirl's Avatar
ya the heat pumps we are installing in all the units in the tower Im on all have their own.
I can drink you pretty.......
BCSparkyGirl is offline   Reply With Quote
Old 10-26-2009, 01:02 AM   #9
Hack and Rat all in one
Peter D's Avatar
Yes, the EC's always hook them up. I think he just meant that it's not required to bring an additional 120 volt feed for the receptacles. One 480 volt feed and done.
Old 10-26-2009, 01:06 AM   #10
"A" inside wireman
randomkiller's Avatar
It all comes down to the job specs, most of the commercial jobs we have done in the last few years have had them OEM.
"One Nation Under God"
Old 10-26-2009, 06:57 AM   #11
Ratus Maximumus
Bob Badger's Avatar
Thanks Pete, yes I meant we terminate the feeder as well. But we do not have to play around trying to find a good place to hang the disconnect, install the receptacle or supply it with another circuit.
Many times the supply and return duct smokes are also factory installed and all we have to do is monitor them with the FA system.
Bob Badger
MA, RI, CT
Old 10-26-2009, 07:52 AM   #12
Burger Flipper
TOOL_5150's Avatar
Gotcha!
~Matt
Colt Disconnects Idaho Abe Vintage Electrical 6 07-11-2009 04:09 PM
Old duplex outlet with built in plate fdew Vintage Electrical 4 04-14-2009 07:31 PM
New Work in Bldg Built In 2000 Randy L NEC Code Forum 5 01-24-2009 08:42 PM
Code for disconnects at UPS brucelaird Services and Service Equipment 0 03-20-2008 05:45 PM
Isolator switched for built in appliances abigbluecat NEC Code Forum 0 10-17-2007 05:51 AM
