Closed Thread
Old 08-13-2008, 10:08 PM   #1
Default Can I change light fixtures without an electrical Lisence?
Hello all,
I jumped over from Contractor talk. I wanted to know If I could change light fixtures without an electrical lisence, simple two wire connection. I have already asked the E-1's I work with but failed to get a straight answer. I need to locate documentation in either case, go/no go.
TIA
sage is offline
Old 08-13-2008, 10:20 PM   #2
Yes you can, as well as switches and receptacles - it is considered general maintenance. However, if you are not quite sure of the reconnection - call an electrician
muck is offline
Old 08-13-2008, 10:25 PM   #3
It depends on each juristiction. I always considered changing fixtures as maintenance. Adding a circuit or running wire would require a license and permit.
frostyfingers is offline
Old 08-13-2008, 10:30 PM   #4
Thanks for the replies. No, I am sure of the connections. I just need to find some documentation, as someone in town hall is looking to break my stones.
sage is offline
Old 08-14-2008, 07:15 PM   #5
JohnJ0906's Avatar
You need to check with your local and state laws. The answer to your question depends on the laws where you work.
John from Baltimore
"One day at a Time"
JohnJ0906 is offline
Old 08-16-2008, 02:05 PM   #6
As stated in the sign up page, ElectricianTalk.com is designed for electrical industry professionals to discuss issues and topics related to the electrical trades and related industries.
Many of our professionals are also members at DIYChatroom.com & ContractorTalk.com and are looking forward to assist you with your needs.
Please leave questions like this on ContractorTalk.com
Thanks.
Speedy Petey is offline
Closed Thread
Elco recessed light fixtures Slider Lighting Design 9 03-15-2010 07:23 PM
union with bad lisence fl.boy Union Topics 53 09-21-2008 03:30 PM
Flourescent fixtures scottm1 General Electrical Discussion 3 08-29-2008 08:53 PM
Support Of Lay-In Fixtures... Hoosier_Daddy Other Codes and Standards 6 08-13-2008 03:09 PM
Industrial Style Fixtures MDShunk Lighting Design 0 09-30-2007 10:59 AM
