Closed Thread
Old 04-18-2009, 12:21 AM   #1
zappy's Avatar
Default Can someone please explain...
I want to tap off a existing outlet in a bedroom. This outlet is ungrounded, and add a switch and a light. Please explain the ways this can be done to code.
"In thee abundance of water, the fool is thirsty"
zappy is offline
Old 04-18-2009, 12:57 AM   #2
Mighty Rat
Minuteman's Avatar
Use a GFCI outlet and install 12/2 or 14/2 with ground. Yes, there is a chance of nuisance tripping, but it would satisfy code.
Proud dad of Sgt. Mickey, USMC 0311
"The Few, the Proud, the Infidel."
Battalion Landing team 2/4, 11th MEU
Minuteman is offline
Old 04-18-2009, 01:34 AM   #3
zappy's Avatar
Thanks for your response. But if there isn't a ground in the existing outlet and I run nm cable from that outlet to the switch and the light yes they would be gfci protected but they wouldn't be grounded. And your saying thats OK?
zappy is offline
Old 04-18-2009, 07:18 AM   #4
Art. 406 allows us to use a GFCI and then wire to another receptacle but the egc must not be connected and a sticker that says "No Equipment Ground" must be installed.
I do not see where it is allowed to wire to a light fixture but I am not sure why it cannot be done. Perhaps it is elsewhere in the code.
Also art. 410 section V. requires an EGC
Alice
electricista is offline
Old 04-18-2009, 08:33 AM   #5
Zappy, your profiles says you are a "journeyman". Yet you are asking DIY type questions. What's up with that?
Are you a journeyman steamfitter?
Speedy Petey is offline
Old 04-18-2009, 08:38 AM   #6
Also, please do not start a new thread when you already have one existing on the exact same topic.
Grabbing power from existing BDRM outlet with no EGC
Closed Thread
Surprised to have to explain to semi-retired electrician sparkie Commercial Electrical Forum 5 02-07-2009 05:49 PM
Can Someone Explain what this Test Equipment Is? BuffaloSoundGuy General Electrical Discussion 9 09-15-2008 07:52 PM
How many ways can you explain the reason for saying NO? John General Electrical Discussion 16 03-24-2007 08:52 PM
Someone explain 480 delta 3 phase? rod213 General Electrical Discussion 3 03-17-2007 02:56 AM
