Old 10-30-2009, 08:01 PM   #1
Default Commercial bathroom wiring
I'm wiring up a bathroom in a church, i need to know if i can run a gf circuit in my conduit with my switch as well or do i got to make them separate? i know in residential its seperate. but what are the rules for commercial? so you all know. we gatta bury the pipes, so we're using existing conduit(like 1960ish emt) and old plastered building walls.
CFine is offline   Reply With Quote
Old 10-30-2009, 08:03 PM   #2
I am a RAT.
william1978's Avatar
You can run them together.
Old 10-30-2009, 08:04 PM   #3
Rat Extraordinaire
Is the lighting 277v?
Old 10-30-2009, 08:05 PM   #4
I am a RAT.
That shouldn't matter. They just couldn't be in the same raceway coming into the box where the device's are because in that box it would need a divider.
Old 10-30-2009, 08:09 PM   #5
I am a RAT.
Take a look at 300.3(C)(1) and 406.4 (G).
Old 10-30-2009, 08:14 PM   #6
Rat Extraordinaire
That's my point, and it does matter according to your second sentence.
Old 10-30-2009, 08:16 PM   #7
I am a RAT.
Ok, the op is talking about just the raceway. We need a little more info.
Old 10-30-2009, 08:34 PM   #8
ok we got one raceway right now and that is the orginal and it's hooked into a switch that is gonna be replaced with a motion sensor(low voltage) we need to install the gfi and well we don't wanna cut into the wall more then we need too. can we run the lighting and the gfi together? this entire building is constucted in rigid electrical wise if that gives you an idea how old it is.
Old 10-30-2009, 08:37 PM   #9
I am a RAT.
You can run them together if the light is 120v.
Old 10-30-2009, 08:41 PM   #10
will i need a low volt parition in the box? this box is basically a cut in box. or can i go ahead and run the way through to the gfi?
Old 10-30-2009, 08:44 PM   #11
I am a RAT.
If it is all 120v there is no need for a divider.
Old 10-30-2009, 08:55 PM   #12
any articles in the code book that i might need to look at?
Old 10-30-2009, 08:57 PM   #13
I am a RAT.
Look at these they should help.
Old 10-30-2009, 08:58 PM   #14
ok thanks still learning how to look at the commerical side. i'm so use to houses that when i do commercial i'm kinda lost still
Old 10-30-2009, 09:01 PM   #15
I am a RAT.
You're welcome. You will get the commercial side of it.
bathroom exhaust fans trademan Other Codes and Standards 12 05-02-2009 11:42 PM
bathroom tv question joepud321 UK Electrical Forum 7 03-11-2009 06:19 PM
Requirement for bathroom vent fan? chenley Other Codes and Standards 15 11-18-2008 03:16 PM
Hairdryer in a bathroom TimW Other Codes and Standards 7 01-17-2008 09:47 PM
Help With Electrical In Bathroom dlopdx General Electrical Discussion 1 08-15-2007 07:57 PM
