Old 11-05-2009, 08:13 PM   #21
Default Copper conduit
I have used it's sister/brother... clad in aluminum.Very labor saving but as said about MI cable sometimes hard fit into the terminator connectors. Do not use pulleys for long pulls. The flattening of the circumference makes it impossible to get into connectors.
Old 11-05-2009, 08:20 PM   #22
cdnelectrician's Avatar
Seen that stuff before...do they still make it? I know Pyrotenax makes stainless steel MI cable. Can you imagine working with that stuff?
I used to work in a plant where everything was in MI cable. It was probably installed in the 50's. I should have taken pics, those guys did some NICE work with it. It looked like it came from a factory.
Old 11-05-2009, 08:51 PM   #23
Default copper conduit
I would have to think that it is still used but I don't know for sure. the AL cable was really great where you have a lot of cables in a pipe rack. You could make it into hand made concentric bends and get three to four times as many feeds in a pipe rack as with conduit.
Old 11-05-2009, 09:05 PM   #24
Anyone remember a cable that had an aluminum sheath but inside of it was a single TW75 conductor? Also have seen this sort of cable but with multiple conductors. You could score it with a knife and break it open. Not often I have run into it but it is out there.
Old 11-05-2009, 09:18 PM   #25
Default sopper conduit
That could have been what I was referring to. It's been a long time since using it. We used it extensively in paint factories, ink manufacturers, and chem. plants.We made early errors in pulling in the longer runs thru wire reels. It didn't take long to realize to slip 15 or 20 feet of it thru the reel without stressing and stationing a man at every reel to make sure that that footage of cable remained ROUND so it would go through the connector at the panel.
Old 11-05-2009, 10:29 PM   #26
The stuff I was talking about was terminated with an L-16 (AC90 connector). There may have been a proper connector for it, but whenever I have come across it, they had just used an L-16.
Old 11-05-2009, 10:48 PM   #27
Wow, been a long time but I seem to remember a connector labeled ALSJ, and it was, I think supposed to be named after the guy who developed it.
Old 11-05-2009, 11:29 PM   #28
Licensed Journeyman
nolabama's Avatar
never used MI - btw has anyone seen MDShrunk lately - he on vacation?
Old 11-06-2009, 04:58 AM   #29
I've torn plenty of it out doing retrofit jobs. I do not like it much myself.
Old 11-06-2009, 08:48 AM   #30
Wyome
MI= mineral insulated. I worked at a powerhouse where they used a lot of MI. Mostly for heat trace, but also in some explosion proof and corrosive areas. It is difficult to deal with. Not too bad if you can just lay it along a pipe, but when you have to wrap valves and fittings it takes some work. All the stuff we used was pre-made to length, so if we used up too much wrapping the fittings, then we could be short at the end and have to start over. Alot of places we had to wire two runs together and sometimes the connections were in series, not the standard parallel. New guys who didn't know that could have problems with the breakers tripping. We used stainless worm drive hose clamps to attach to pipes.
Old 11-06-2009, 03:43 PM   #31
Hydro plants, hospital emergency curcuits and class 1 div 1 Like refineries very popular places for MI
But now we use this crap called " life line"in the hospitals and I can tell you some horror stories about pulling it.
sparky105 is online now   Reply With Quote
Old 11-06-2009, 04:34 PM   #32
Unlimited Lic.Electrician
william1978's Avatar
I was thinking the samething. It seems like he hasn't posted in awhile.
This place is pretty good.... JacksonburgFarmer Off Topic 31 03-28-2009 12:25 AM
Shweet!! Another place to learn!! Shado Introductions 6 01-04-2009 01:03 PM
copper nolabama Business, Marketing, and Sales 8 12-05-2008 10:43 AM
2nd place HCECalaska Business, Marketing, and Sales 11 04-13-2007 12:15 PM
