Old 07-15-2008, 08:58 PM   #1
Default distance raceway must be from surge arrestor
What is the distance that a raceway must be from a surge arrestor cable?
cbruce73401 is offline   Reply With Quote
Old 07-15-2008, 09:42 PM   #2
What is a "surge arrestor cable" ?
Old 07-16-2008, 01:25 AM   #3
nap
a real PITA
and if a raceway is required for the surge arrestor cable, how can it be "away" from the raceway?
Old 07-16-2008, 10:35 PM   #4
The cable is the cable for the lightning arrestor. The question was on a test I took and it meant how far must another raceway be from the lightning arrestor cable?
Old 07-17-2008, 02:12 PM   #5
nap
a real PITA
I think you may have two things mixed together here. There is lightining arrestor systems and there are surge supressor systems.
A lighting arrestor system uses air terminals on the roof and s specific cable conductor and such to attempt to direct a lighting strike around a building.
A surge supressor is intended to limit the voltage any gear or equipment is exposed to. Many newer larger panels come with a TVSS designed into them (transient voltage surge supressor). Many other surge supressors are mounted directly on the panel tub of other conveniant locations.
So, am I barking up the wrong tree or are you?
It may merely be the nomenclature you are utilizing being ufamiliar to me.
Your last post does seem to make it as you are speaking of the lightning arrestor system but I just wanted to be clear due to the use of the "surge" in the original post.
Old 07-17-2008, 08:06 PM   #6
If your talking about lightning protection, read 250.106 FPN #2
Jim
wirenut1110 is offline   Reply With Quote
Connecton of distance protection relays speedtronic General Electrical Discussion 4 09-27-2008 09:38 PM
whole house surge arrestor clif2 General Electrical Discussion 1 08-18-2008 09:19 PM
Vintage Raceway 480sparky Vintage Electrical 25 05-19-2008 07:53 AM
water line distance? machinery30 NEC Code Forum 3 09-10-2007 06:01 PM
Arlington raceway frenchelectrican General Electrical Discussion 5 04-23-2007 08:08 PM
