Old 06-20-2007, 01:59 AM   #1
Default Drilling & Notching Framing Members
I am looking for the specific rules from any USA building code that provides the rules associated with the NEC rules in 300.4 covering drilling and notching.Also, has anyone used the new thinner listed nail plates?
Joe Tedesco is offline   Reply With Quote
Old 06-20-2007, 10:55 AM   #2
Ax grinder
raider1's Avatar
Joe,
Here is a quote from the 2006 IRC on drilling and notching of studs:
R602.6 Drilling and notching–studs.
of studs shall be in accordance with the following:
1. Notching. Any stud in an exterior wall or bearing partition
may be cut or notched to a depth not exceeding 25
percent of its width. Studs in nonbearing partitions may
be notched to a depth not to exceed 40 percent of a single
stud width.
2. Drilling. Any stud may be bored or drilled, provided that
the diameter of the resulting hole is no more than 60 percent
of the stud width, the edge of the hole is no more
than
5/8 inch (16 mm) to the edge of the stud, and the hole
is not located in the same section as a cut or notch. Studs
located in exterior walls or bearing partitions drilled over
40 percent and up to 60 percent shall also be doubled
with no more than two successive doubled studs bored.
See Figures R602.6(1) and R602.6(2).
Exception:
Use of approved stud shoes is permitted
when they are installed in accordance with the manufacturer’s
recommendations.
Was this what you are looking for?
Chris
Old 06-20-2007, 05:50 PM   #3
I don't like the thinner nail plates that they're making now for sale to electricians, so I buy my nail plates at the plumbing supply house. They still sell the "real" nail plates, and they seem to just be of better quality overall.
Old 06-23-2007, 09:09 PM   #4
Thanks for the replies. I have discovered some additional information that will be helpful when discussing this subject in the field during seminars.
Recessed light drilling tip MDShunk Lighting Design 36 03-14-2010 10:52 PM
mast drilling tool R Squared Tools, Equipment and New Products 19 09-04-2008 06:57 PM
Drilling holes... twintask Tools, Equipment and New Products 28 04-07-2008 10:31 PM
MC cable and wood framing Rikki Other Codes and Standards 54 02-07-2008 08:29 PM
New Members - Tell us where you are from! Speedy Petey Introductions 0 05-16-2007 01:57 PM
