Old 10-06-2010, 01:19 AM   #1
Default Flexible Conduit Inside Wall
Can flexible metal conduit be ran inside of a wall cavity? For example, from a load center up through the top plate and into the attic? 348.10 gives me the impression this is okay.
Alternatively, can liquidtight (either LFNC or LFMC) be ran inside of a wall cavity? 350.10 and 356.10 say it can be used in concealed locations for X reasons.
Thanks in advance!
jamgood96 is offline   Reply With Quote
Old 10-06-2010, 01:25 AM   #2
I void warranties
Jlarson's Avatar
As far as I know running FMC in a wall cavity is all good, now the last time I fished a wall was IDK, so I'm not really the best source of info for this.
The best never stop learning.
Jlarson is online now   Reply With Quote
Old 10-06-2010, 01:34 AM   #3
Just don't quote me wrong but if I did recall there were one section in the NEC mention LFMC and LFNMC are limited with length.
Unless you snag into Chicago codes they have strict requirment with it.
Merci.
Marc
Old 10-06-2010, 01:36 AM   #4
Master Plumber
TOOL_5150's Avatar
Merci.
Marc
ONLY when they are used as the EGC, otherwise unlimited length.
Also, your installation is complaint and does NOT need to be secured when fished in a wall.
~Matt
Poor planning on your part does not constitute an emergency on my part.
Old 10-06-2010, 01:37 AM   #5
I void warranties
Jlarson's Avatar
In certain situations when used as a EGC, otherwise all good. I almost never use FMC, LMFC, or LFNMC for anything else but short connections to motors, equipment, and switches/instruments.
The Following 2 Users Say Thank You to Jlarson For This Useful Post:
frenchelectrican (10-06-2010), John Valdes (10-13-2010)
Old 10-06-2010, 06:17 AM   #6
Just keep in mind that the 360 degrees between pull points rule still applies . That's really easy to exceed with flexible raceways without even realizing it. Keep an eye on what you're doing.
The Following 2 Users Say Thank You to MDShunk For This Useful Post:
frenchelectrican (10-06-2010), jwjrw (10-06-2010)
Old 10-12-2010, 10:12 PM   #7
...and no concealed angle connectors
voltz is offline   Reply With Quote
Old 10-13-2010, 01:06 AM   #8
I like to run smurf tube to the attic, and to the crawl, from the panel, if I ever have the opportunity.
Prevents the wall from having to be opened down the road, just to put in another circuit.
In some situations I'd be sure to duct seal that smurf tube. Don't want cold air meeting moist warm air if you know what I mean.
miller_elex is offline   Reply With Quote
Old 10-13-2010, 01:27 AM   #9
I void warranties
Jlarson's Avatar
The last one I did I had some 1 1/4" EMT scrap laying around so I put that in as a future conduit.
Old 10-13-2010, 01:43 AM   #10
Master Plumber
TOOL_5150's Avatar
About once a year, i get a job where the last guy thought about the next guy, me in this case, and had dome something cool like that.
Id just like to find the guy and buy him a case of cold ones. It really makes my day.
Last job that was like that had a 12/3 from the panel - ground and noodle made up, black and red wirenutted in th panel and the other side was stripped and terminated in a 4S in th basement. It was about 8 dollars of material and saved me a huge headache.
~Matt
Old 10-13-2010, 01:57 AM   #11
erics37's Avatar
Yah. Tornados.
- Eric
Old 10-13-2010, 02:23 AM   #12
I void warranties
Jlarson's Avatar
Yeah well when you have spent years fighting minimum installs on service calls you figure out ways to make yours better for your self and the next spark that comes along.
Old 10-13-2010, 11:22 AM   #13
Good at being Evil
Shockdoc's Avatar
I'm on the same level.......great thing to do.
Old 10-13-2010, 12:13 PM   #14
Fried Bologna um um good!
jwjrw's Avatar
We usually pull a few up and down for future use......put them in a box and don't terminate them in the panel till needed.
Old 10-13-2010, 12:29 PM   #15
Good at being Evil
Shockdoc's Avatar
I recently had to snake a #8 thru one of those some hack buried in the wall at the panel. Same hack installed a 100 amp sub panel in PVC/EMT and greenfield thinking the pvc would act as a EGC.
Old 10-14-2010, 08:09 PM   #16
I can imagine what your wire looked like when it come thru that connector
Old 10-14-2010, 08:34 PM   #17
Bababoee
captkirk's Avatar
~Matt
About a year and a half ago I had a job to add three ceilling lights in three different rooms or a really old home with nasty plaster and lath. When I measured out and started to cut the first ceiling box in Bang, my jab saw hits the origional octagon box in the ceiling covered over with plaster and a blank cover...
..I got so excited that I went into the other rooms and took a closer look at the centers and Voiala...they all had boxes in the ceiling covered over...WTF who covers over center lights...? I told the lady I would pretty much be there all day and I was out in a few hours.....Can anyone tell me when does that EVER happen...?
Full time Bovine Scatologist.
captkirk is online now   Reply With Quote
Old 10-16-2010, 02:51 PM   #18
Good at being Evil
Shockdoc's Avatar
I had that luck once. That is rare. She must have complemented you on a clean hole free job.
flexible nonmetallic conduit question cannio NEC Code Forum 29 06-13-2010 02:06 PM
Romex in flexible metal conduit waco General Electrical Discussion 6 01-07-2010 04:14 PM
NM-B cable run inside 2" conduit partimer31 NEC Code Forum 12 09-19-2009 03:59 PM
3/8 flexible conduit ChrisinAr General Electrical Discussion 4 03-27-2009 06:11 PM
Cutting flexible conduit MDShunk Tools, Equipment and New Products 19 04-21-2008 05:15 AM
