10-18-2009, 12:26 PM
Hack and Rat all in one
Fused A/C disconnects
Is there any advantage to adding localized fused protection for A/C equipment even when the nameplate allows a breaker?
Only reason I ask is that I picked up a bunch of fused A/C disconnects at HD on clearance for $1.40 each.  I figure at the very least I'll put some pieces of copper tubing in there to bypass the fuse holders.
10-18-2009, 12:47 PM
I've had HVAC contractors require a fused disconnect. I definately would have bought all I could at that price. No copper tubing though.
10-18-2009, 01:29 PM
Good job getting those discos for that price!
If the nameplate allows for max fuse or hacr breaker for example, I don't see how it can hurt to have a fused disconnect but if it's labled "max time-delay fuse" then it's required, not sure what the hvac guy has do with your disconnect. most hvac installers that I work with just tell me the amperes over the phone or give me a cut-sheet so i know what awg to run before hand. After that, I do what I need to do, they do what they need to do and the unit is up and running.
10-18-2009, 01:36 PM
There's still some equipment out there that says "max fuse size". I'd save those discos for the special occasions where the equipment must have fuses. Other than that, I see no advantage.
-Marc, ABC, XYZ, PhD, 1-2-3
10-18-2009, 02:11 PM
Thanks, I didn't see any advantage either, but wanted to make sure.
As an FYI, HD and Lowes are clearing out their stock of Square D A/C disconnects. I bought a case of non-fused 60 A regular pull out style for $3.23 each on clearance at Lowes. HD also had them on clearance for the same price. Good time to stock up now for next year.
10-18-2009, 02:25 PM
One disadvantage to using fused disconnects for A/C equipment is that in the event of a fault, a fuse will blow before a breaker will trip.
A fuse needs to be replaced, a breaker can be reset.
Rob
10-18-2009, 02:53 PM
Rob
That is a good thing.. HO will reset a circuit breaker, but most won't go near a fuse that needs a "puller" to get it out
I don't think Peter would mind doing the service call
Terrorism is a naughty word.. let me be clear, I intend to be PC when ever it makes me look good
10-18-2009, 02:55 PM
Haha...yeah. I do HVAC work on the side now.
10-18-2009, 02:58 PM
So on your resume, you list HVAC experience because you changed a fuse?
I forgot thermostat "analysis"
10-18-2009, 03:01 PM
Ratus Maximumus
Maybe you could get a job as a full time spelling cop?
Bob Badger
Electrical Construction and Maintenance
MA, RI, CT
10-18-2009, 03:11 PM
good one
10-18-2009, 03:19 PM
Fuses ofter better protection than breakers. They clear faster than breakers and if properly sized are better for arc flash mitigation.
"Pay attention son, this is for your own good." - Foghorn Leghorn
10-18-2009, 03:22 PM
"A" inside wireman
And what just have him jump right over the yellow striper and put him out of business?
"One Nation Under God"
10-18-2009, 03:23 PM
"A" inside wireman
I bet he is cutting the copper to length already.
10-18-2009, 03:26 PM
Ooohh...the big scary doggy is back.
10-18-2009, 03:27 PM
Does it make you feel like a big man to make fun of everybody?
10-18-2009, 03:36 PM
#18
"A" inside wireman
Nope, it's called a sense of humor, I exercise mine all the time. It keeps me young and smiling. If you think I'm bad you need to hang out with a group of Marines sometime. I'm just having fun, unlike a few guys on here that feel it's necessary to spell check and play grammer teacher to the forum as a whole.
10-18-2009, 03:38 PM
#19
You have no sense of humor.
10-18-2009, 03:43 PM
#20
It's "grammar", not "grammer".
