Garbage Disposal and Dishwasher on same circuit. - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
View Poll Results: Disposal and Dishwasher on the same circuit
Yes 43 62.32%
No 26 37.68%
Voters: 69. You may not vote on this poll
Old 08-20-2011, 12:43 PM   #41
gold's Avatar
Rewards Points: 2,048
Send a message via Yahoo to gold
Originally Posted by guschash View Post
I usually run 2-20amps circuits. I like to run #12 for all receptacle circuits, I know its over kill but there seems to be more things being plugged in these days.
Waste of money.
Define "Anger Management"
“Free at last, Free at last, Thank God almighty we are free at last.”
gold is offline   Reply With Quote
The Following 2 Users Say Thank You to gold For This Useful Post:
NolaTigaBait (08-20-2011), user4818 (08-23-2011)
Old 08-20-2011, 02:03 PM   #42
I would say yes, if you know for sure that the dishwasher manufacturer doesn’t require their equipment to be supplied by a 15 or 20A individual branch circuit.
I guess you could be proactive and run it by the inspector beforehand, to see what he says.
Seems most resi grade disposal manufactures only care about having a switch within reach of the sink, so could probably care less about how you supply their equipment.
Old 08-20-2011, 03:36 PM   #43
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,562
This is what my dishwasher installation guide says:
You must have:
■ 120-volt, 60 Hz, AC-only, 15 or 20 amp fused electrical supply.
■ Copper wire only.
We recommend:
■ A time-delay fuse or circuit breaker.
■ A separate circuit.
If direct wiring dishwasher:
■ Use flexible, armored or nonmetallic sheathed, copper wire
with grounding wire that meets the wiring requirements for
your home and local codes and ordinances.
■ Use strain relief method provided with house wiring junction
box or install a UL Listed/CSA Approved clamp connector to
the house wiring junction box. If using conduit, use a
UL Listed/CSA Approved conduit connector.
If connecting dishwasher with a power supply cord:
■ Use Power Supply Cord Kit (Part Number 4317824) marked
for use with dishwashers. Kit contents include:
■ Voltex, Inc., UL Listed 16-gauge 3 wire power supply cord
with 3 prong grounded plug.
■ Neer C-500 ⁷⁄₈" strain relief.
■ 3 wire connectors.
■ Part Number 302797 grommet.
Follow the kit instructions for installing the power supply cord.
■ Power supply cord must plug into a mating three prong,
grounded outlet, located in the cabinet next to the dishwasher
opening. Outlet must meet all local codes and ordinances.
IMPORTANT: If you plan to install a garbage disposer, an
additional separate 120-volt, 60 Hz, AC-only, 15 or 20 amp fused
electrical supply is required.
link:
http://www.kitchenaid.com/flash.cmd?...uct/KUDD03DTSS
Old 08-20-2011, 03:56 PM   #44
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
It's too bad DW's are rated for 10 amps; you never have 10 amps running at one time: you got the washing motor running at one time and then the heater after (if you even use it).
I'd rather be sleeping.
Old 08-21-2011, 01:22 AM   #45
Skipp's Avatar
Rewards Points: 250
Does this recepticle under the sink need to be GFI? I know it used to be ok for a standard recepticle. But it seems every NEC cycle more GFI requirements are added.
Skipp is offline   Reply With Quote
Old 08-21-2011, 05:41 PM   #46
That is incorrect on some (most) dishwashers sir.
Many use the heater while the motor is running to heat the water back up to proper temperature during wash or rinse cycles. Mine also has "Temperature Boost" to heat the water even more. (Maytag Performa Portable)
For that reason, and the fact that most manufacturer's instructions call for a dedicated circuit, I voted no.
Old 08-21-2011, 08:03 PM   #47
Podagrower's Avatar
Rewards Points: 568
When I was doing resi, I was taught to pull a separate 20 amp circuit for the dishwasher and disposal. I've done it that way so long, I don't think I could force myself to do it any other way.
Now, let's say you use a 3 way switch. Yes it is a violation of the listing for the switch. But then your dishwasher and disposal can't run at the same time. Works well when you forget a homerun (once), I suppose you could build a relay setup under the sink to accomplish the same thing.
Podagrower is offline   Reply With Quote
Old 08-21-2011, 08:53 PM   #48
gold's Avatar
Why tho? Its 16.9 amps on a 20 amp circuit for an occasional few seconds.
Old 08-21-2011, 09:36 PM   #49
I was taught to pull separate 20 amp circuits for the DW and GD.
In my neck of the woods here they want a disconnect for the DW under the sink.
I just wanted to add the last time I hooked up a disposal off of an existing 15 amp screw in fuse under the sink with 20 amp wire.... I had to go back because it blew the screw in 15a fuse. I went back with a 20 amp fuse and amped the circuit with my fluke rms. It drew 14.?? on start up and if I remember correctly 11 running with some food in there. So be careful. I would imagine the cheap ones have a low draw but the higher end models may draw more. I'm sorry I can't remember what size it was. All was fine after the fuse swap.
Island Electric is offline   Reply With Quote
Old 08-21-2011, 11:45 PM   #50
220/221's Avatar
Rewards Points: 3,564
Here it's one 20A circuit, half switched recep under the sink.
SOP since the 70's
The Following User Says Thank You to 220/221 For This Useful Post:
Jlarson (10-27-2011)
Old 08-22-2011, 10:24 AM   #51
Ax grinder
raider1's Avatar
Rewards Points: 1,080
Depends on if the receptacle under the sink is in a kitchen or not. A receptacle installed under a wet bar sink for a disposal would need to be GFCI protected but a receptacle installed under a sink in a kitchen would not.
Only receptacles serving the countertop in kitchens require GFCI protection whereas all receptacles within 6' of the edge of a wet bar sink require GFCI protection.
Chris
Old 08-22-2011, 10:27 AM   #52
Ax grinder
raider1's Avatar
If the manufacturer Recommends that the appliance be on a dedicated circuit then that is not a 110.3(B) requirement. It would only be a listing requirement if the instructions mandated or required a dedicated circuit.
Chris
Old 08-22-2011, 04:24 PM   #53
I_get_shocked's Avatar
Rewards Points: 516
This is a good thread. I believe that the single 20A circuit is legal and will suffice based on the articles cited so far, so long as the mfg doesn't require any dedicated circuits.
last shocked on 6/24
I_get_shocked is offline   Reply With Quote
Old 08-23-2011, 05:50 PM   #54
Mr. Troubleshooter's Avatar
Originally Posted by electures
1/3 HP Disposal, 6.8 amps, 120V
Dishwasher 9.9 amps, 120V
Are they permitted on the same 20 amp circuit. I will reserve my thoughts for later.
PLEASE VOTE!!
I'm not sure. I don't know much about motors but I don't see no reason not to put them both on the same 20 amp
Mr. Troubleshooter is offline   Reply With Quote
Old 08-23-2011, 05:52 PM   #55
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I need to do this tommorow , customer added a disposal unit.
Old 08-23-2011, 11:13 PM   #56
PLEASE VOTE!!
Yes here in AZ very common
Ponderosa electric is offline   Reply With Quote
Old 08-24-2011, 01:46 AM   #57
Rewards Points: 3,332
Chris
I'll take it we are talking about dwellings here and not commercial kitchens.
Commercial kitchen, its gfi no matter where in the kitchen last time I checked.
Old 08-24-2011, 10:56 AM   #58
Ax grinder
raider1's Avatar
Correct, what I was referring too was a dwelling unit requirement.
Chris
disposal of... BuzzKill General Electrical Discussion 12 07-19-2011 03:59 PM
garbage disposal spider General Electrical Discussion 3 05-20-2011 05:48 PM
Dishwasher cord daverk87 NEC Code Forum 25 04-18-2011 10:29 AM
garbage drill bits Josue Tools, Equipment and New Products 30 01-01-2011 01:39 PM
garbage disposal dwaincyrus General Electrical Discussion 4 03-23-2008 06:41 PM
