Old 10-29-2009, 08:01 PM   #1
Default Identifyng Neutral
Ran into a situation today where someone used a red wire as a neutral in a 120v circuit. They identified it as a neutral by one band of white tape near the end. It was number 12 wire. Am I reading the code right that this is a violation?
If you use a control cable and say you have 7 conductors is it legal to use a blue as a neutral?
petek57 is offline   Reply With Quote
Old 10-29-2009, 08:06 PM   #2
Seen your member
I see nothing in 200.6(A) that would make it legal to use a red.
Old 10-29-2009, 09:46 PM   #3
Briancraig81's Avatar
You can't re-mark anything smaller than a #8.
Briancraig81 is offline   Reply With Quote
Old 10-29-2009, 09:55 PM   #4
EBFD6's Avatar
Close, but it's actually #6 AWG or smaller 200.6(A)
EBFD6 is offline   Reply With Quote
Old 10-29-2009, 10:00 PM   #5
I was going to say #6 but I had it stuck in my head it was #8. Thanks for the correction .
Old 10-29-2009, 10:19 PM   #6
EBFD6's Avatar
No problem. This is probably one of the most violated codes. I know I re-identify #8 all the time (shh, don't tell anyone).
Old 10-29-2009, 10:55 PM   #7
Default Blue for grounded conductor is OK
Fact:
For jacketed cords furnished with appliances, one conductor having its insulation colored light blue is allowed in accordance with the NEC.
Joe Tedesco is offline   Reply With Quote
Old 10-29-2009, 11:16 PM   #8
Toronto Sparky's Avatar
Then how do you Americans run the wiring to B/B heaters?
I keep getting told you can't get the red/black romex in the U.S.
I always used to tape up the white in the heater and the panel before the red/black stuff showed up.
I have also done that with red/black/blue cabtyre when I needed a neutral in it.
Don't fight .. Play nice!
Old 10-29-2009, 11:25 PM   #9
Default Identifying neutrals
Whatever a conductor is used for, it must be identified appropriately. If whatever color wire is used for something different than what is the norm, it must be tagged appropriately. I would probably use more than one band of white tape... or natural grey, but to me it is okay if marked appropriately. How many have used the NEUTRAL,or white wire, as a conductor in a switch loop?
Old 10-29-2009, 11:37 PM   #10
Seen your member
We can remark a white conductor as an ungrounded, but can't mark an ungrounded (say, #10 or 12) with white tape. It's a one-way street.
Old 10-30-2009, 10:54 AM   #11
You don't say if this is wiring in romex or individual wire's in a conduit. Why would he need to use the red for a neutral in romex, it already has a white. Did he use the white for ungrounded and tape it red or black? If this is a commercial project with the wire in conduit there is no reason that would satisfy an inspector to use a red or any other color other that white or gray for a neutral.
David Channell SSE
Old Spark is offline   Reply With Quote
Old 10-30-2009, 01:50 PM   #12
I’m guessing the OP must be referring to NM or UF cables?
IMO, when wires are pulled in conduit or tubing, I don’t see anything in 200.6 that would prevent using any color #6 or smaller conductor as long as it is ultimately identified by a white or gray outer finish along it’s entire length. I also don’t see any wording that restricts using white or gray tape to accomplish this.
Likewise if the conductor were any color other than green, you could use three white stripes over its entire length.
Obviously, this would be impractical for long runs, but would be useful if you were installing a small 60A feeder in conduit for a subpanel directly adjacent to another panel and just need a few feet of #6 THHN wire for your neutral. You wouldn’t need to run to the supply house just to buy a few feet of white #6 wire, since you could just identify any color conductor with white over its entire length, or with three white stripes over its entire length for other than a green conductor and still be in compliance with 200.6.
Old 10-30-2009, 02:19 PM   #13
I know what you are saying with wire of size 6 or larger, but I was answering a question regarding wire size 12. Phase taping #12 is not allowed in commercial unless it is with romex or other jacketed cables. I run into work by someone who abviously is using what ever he has on his truck and not only is phase taping size 10 and 12, but changes colors at each j-box. It sure makes trouble shooting a problem difficult when the wire starts out as black and ends up blue or red at the other end. I don't expect anyone who joins us in this forum to be the one who do this kind of bad work.
David Channell
Old 10-30-2009, 04:33 PM   #14
Better than a butt splice in the conduit with two different color wires.. (I've seen that!)
Service work teaches you to expect anything!!!
Old 10-30-2009, 04:58 PM   #15
I was merely attempting to explain what I see when I read 200.6 in the NEC.
If someone were to say that the white or gray outer finish of #6 and smaller, [which would include #6,8,10,12,14,16] wire in conduit being used as a neutral could only be factory applied, I would say to them that if that were true, they could not use white or gray THHN/THWN either, since the outer covering is not white or gray, it is clear.
Old 10-31-2009, 03:42 AM   #16
Default Further Info
Just to clear it up. The red wire w/ white tape I found was in fact in conduit.
Any ideas about control cables? Some of which do not come with a white.
Old 10-31-2009, 03:54 AM   #17
Site Idiot Smacker
BCSparkyGirl's Avatar
wow, they make you tape it red? we have one inspector that gets bored enough to want that..........but man do I find that tedious.
Don't make me bust out the apprentice stick!
BCSparkyGirl is offline   Reply With Quote
Old 10-31-2009, 01:36 PM   #18
It's actually #4 and larger that is allowed to be re-identified. Smaller than #4 is a no-no. Having said that, I still do it, because as far as violations go, this one is like double parking, or doing 58 in a 55.
Old 10-31-2009, 04:32 PM   #19
You're allowed to identify the grounded conductor at the time of termination for multiconductor cables like that “where the conditions of maintenance and supervision ensure that only qualified persons service the installation”. See 200.6 [E], exception in the ‘08 NEC.
I would say it’s up to the AHJ, but my best guess would be that this likely rules out resi and most light commercial, but probably would be okay in institutional, heavy commercial and industrial facilities that have qualified in-house electrical maintenance personnel. JMO though.
Old 10-31-2009, 08:24 PM   #20
David Channell
Dave,
Is this a local rule where you are?
I commonly see black THHN/THWN #12 or #10 ungrounded conductors identified with brown, orange, yellow or black, red, blue tape at pull points and terminations during installation. I can’t say that I remember seeing anything in the NEC not allowing this.
No neutral wire tamato General Electrical Discussion 1 03-28-2009 05:46 PM
MWB ckt neutral subelect General Electrical Discussion 15 03-06-2009 10:37 AM
Neutral voltage lectric_hand6855 General Electrical Discussion 8 01-25-2009 06:35 AM
120 v in neutral??? lamino69 General Electrical Discussion 10 01-14-2008 09:34 PM
Neutral? brian john NEC Code Forum 14 04-10-2007 11:55 AM
