Originally Posted by Toronto Sparky
Then how do you Americans run the wiring to B/B heaters?
I keep getting told you can't get the red/black romex in the U.S.
I always used to tape up the white in the heater and the panel before the red/black stuff showed up.
I have also done that with red/black/blue cabtyre when I needed a neutral in it.
Raceway - use the proper colors (anything but white or green for ungrounded).
Cable assembly - reidentify the white wire.
I wouldn't mind having red/black romex, but it's just another thing to stock. Are you required to use red/black in Canada?
