Old 07-29-2008, 05:30 PM   #1
P.M. Outstanding Senior
pudge565's Avatar
Send a message via AIM to pudge565
Default Locks on Main Service Disconnect.
Is there a code issue with haveing a lock on an outdoor Main service disconnect that is right below the meter can?
Old 07-29-2008, 06:20 PM   #2
Nope, not at all. Feel free to lock it on or off. There is no requirement that any disconnect be immediately operable in the event of an emergency. There's only a requirement that they be there. Lock 'em if you want to. The fire department can get that lock off there in seconds flat if they feel the need.
I'm an electrician, not a magician.
Old 07-29-2008, 11:38 PM   #3
pudge565's Avatar
Ok thank you Md I was asking because I am going to submit a proposal that there must be a main disconnect outside near the meter can so in the event of a fire the FD can shut off power without pulling the meter and worring about arc flash. I had posted it on Diychatroom to get peoples ideas on it and someone said what about kids shutting it off for te fun of it. Then when I said just put a lock on it they said that you can't lock them. I am going to wait til I go back to votech on the 25th of august to start on it so I can get help with the proposal. BTW I am a junior volunteer firefighter that is why I am going to make the proposal.
service disconnect location? electromanj Services and Service Equipment 15 06-07-2008 05:09 PM
Use for channel locks/pump pliers? iAmCam Tools, Equipment and New Products 29 05-27-2008 03:03 AM
Residential 400a. Service Both Main Tripping Karpo1961 Services and Service Equipment 3 04-08-2008 11:14 PM
Sizing Main Disconnect For Control Panel? Voltshead Services and Service Equipment 5 03-21-2008 06:24 PM
Clearance for a service disconnect joleesparkey Services and Service Equipment 1 03-11-2008 03:21 PM
Electrician Talk © 2006 - 2010 The Building Network LLC
