Old 01-28-2007, 12:26 PM   #1
Default Metal Stud bushings
Metal studs have holes of various sizes and sorts. Some of the common configurations are:
You need to use some sort of bushing when wiring with Romex to comply with paragraph 300.4(B)(1) of the NEC, which states that: "in both exposed and concealed locations where nonmetallic-sheathed cables pass through either factory or field punched, cut, or drilled slots or holes in metal members, the cable shall be protected by bushings or grommets covering all metal edges and securely fastened in the opening prior to installation of the cable." Not all bushings will work with all types of holes in the metal studs. There are bushings available that are pretty universal:
This picture of metal studs from Derek Pasch, Staffing Specialist at Meisner Electric in Delray Beach, FL, begs the age old question. Why is there always one stud or two in a wall of perfectly aligned holes that doesn't line up with the rest?
Old 01-28-2007, 09:55 PM   #2
It's a conspiracy. By the company that sells stud punchs. Or the EC is on T&M and slipped a buck to the framer.
acrwc10 is offline   Reply With Quote
Data cable pulls, EMT sleeves through walls, NO BUSHINGS !! BP_redbear Structured Wiring 4 11-15-2008 07:03 PM
question about metal dnme01 General Electrical Discussion 32 09-11-2008 08:03 PM
Grounding metal boxes Mackie NEC Code Forum 16 03-21-2008 11:36 PM
Stud WelderPower Supply markmc UK Electrical Forum 4 03-03-2008 01:54 PM
Metal Halide fixture InControl General Electrical Discussion 8 04-16-2007 10:34 PM
