Minimum Conductor Bending radius - Electrician Talk - Professional Electrical Contractors Forum
Old 08-27-2009, 09:37 AM   #1
Default Minimum Conductor Bending radius
I know it is good wiring practice not to bend wiring (THHN) at right angles, but what code covers this? I only find conductor bending radius guidelines for over 600 Volts in NEC.
pie man is offline   Reply With Quote
Old 08-27-2009, 09:42 AM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Why, that would be 110.74.
Old 08-27-2009, 10:12 AM   #3
Rewards Points: 1,248
Also 314.28 A 2 (from 110.74) and 408.3 G and 408.55 which refers you to Tables 312.6 A & B for "L" and "S or Z" bends respectively.
ralpha494 is offline   Reply With Quote
Old 08-27-2009, 10:33 AM   #4
Toronto Sparky's Avatar
Rewards Points: 1,008
Never had a problem as long as it's stranded wire.. Chuck the solid in the trash..
Don't fight .. Play nice!
Old 08-27-2009, 11:52 AM   #5
Default minimum conductor bending radius in panelboards
I see 110.74 referencing 314.28. There is ample space in the industrial control panel where the wiring exists, my issue is that the wiring is dressed with all of the THHN bent at right angles. I don't see the insulation cracked or discolored, so maybe it does meet code. It just rubs my fur the wrong way. Worse yet, the OEM has an interpretation from a NFPA engineer that says, "However, there are no specific requirements with regard to angle of a bend or a minimum bending radius of the curve for wire/conductor less than 600 volts in either the NEC or NFPA 79.".
Old 08-27-2009, 11:57 AM   #6
RePhase277's Avatar
Rewards Points: 3,118
I say the same about stranded smaller than #10.
Old 08-27-2009, 12:11 PM   #7
Default bends
I guess table 312.6(A) implies that #10 and smaller can be bent to your personal delight and still meet code.
#8 begins the implied minimum bending radius of 1-1/2".
I guess all the years of poo-pooing the practice of dressing #10 and smaller wire at right angles was unnecessary.
Old 08-27-2009, 01:38 PM   #8
Opinions vary.
I normally work alone.. Stranded wire is far less problematic when pulling a 200Ft run alone.
Ever tried to get solid #12s in a pull elbow by yourself? Just a pain.
As well as when fishing a conduit that is already half full.
Yes Solid is much easier to dress in a panel, but for me thats where it ends.
Wanted: Short radius bender randas Electrician Swap 8 09-12-2009 12:44 AM
Short radius bender randas Tools, Equipment and New Products 11 08-01-2009 10:40 PM
minimum charges. Bkessler Business, Marketing, and Sales 15 02-18-2009 11:06 AM
grounding electrode conductor and grounded conductor nolabama Services and Service Equipment 6 01-12-2009 01:51 AM
Short radius benders calimurray General Electrical Discussion 29 01-08-2009 04:21 PM
