Old 10-29-2009, 09:49 PM   #21
Unlimited Lic.Electrician
william1978's Avatar
There is no price tag you can put on a life.
Old 10-29-2009, 09:51 PM   #22
Then you need to feed your kids better.
Old 10-29-2009, 09:55 PM   #23
B4T Scotchkote installer
Black4Truck's Avatar
Originally Posted by idontknow View Post
What about the garage, bath receptacles & lighting, outside lighting and receptacles.
On the other hand, if your washing machine is in a closet, it would have to be AFCI protected. Unless I missed an exemption.
Good point
Black4Truck is offline   Reply With Quote
Old 10-29-2009, 10:03 PM   #24
Stiff Member
idontknow's Avatar
Originally Posted by william1978 View Post
The AFCI will take it out then.
This cord happens to be in the kitchen, where the hungry children are.
They're her kids and I shouldn't have to support the little runts. Bad enough they can't live with their own dad. She gets child support but that barely covers her cigarette habit.
idontknow is offline   Reply With Quote
Old 10-29-2009, 10:14 PM   #25
EBFD6's Avatar
But if the child gnaws on a 2 wire cord, the GFI won't protect them either.
Why not? Are you saying the GFI won't trip because it is two wire (no equipment ground conductor)?
If that is what you're saying, that is incorrect. GFI's do not require an equipment ground to trip.
The child would experience a shock for a short period, but the GFI would trip.
EBFD6 is offline   Reply With Quote
Old 10-29-2009, 10:21 PM   #26
If the child is NOT touching a ground and simply bites into a 2 wire cord, then a GFCI device will offer no protection. If the child IS in contact with a ground and is able to conduct about 6ma to ground from the ungrounded conductor, then the GFCI will open.
GFCIs are protection ONLY against leakage currents to ground and do not protect against all hazards. In any case, the TR feature of the GFCI would offer zero additional protection in this instance.
Joe71 is offline   Reply With Quote
Old 10-29-2009, 10:41 PM   #27
EBFD6's Avatar
False!
GFCI's measure current imbalance between the hot and neutral conductors.
Read Here
Old 10-29-2009, 10:45 PM   #28
Seen your member
Not if the shock is line-to-neutral. That is simply a load, the line and neutral will be balanced, and the GFI does not react.
Old 10-29-2009, 10:53 PM   #29
False!
Read Here
By definition, currents flowing to GROUND by some other means other than the Neutral ARE current imbalances detected and acted upon by a GFCI device. That is indeed the current which will/can trip a GFCI as in my example.
Old 10-31-2009, 10:28 AM   #30
Available. I used P&S and the device was only face marked WR, but the package also read TR and the device had gates. The inspector didn't argue, he did insist that the garage door opener recep on the cieling be TR and GFI protected. I understand not wanting toddlers to climb on the SUV with paperclip in hand, and I don't mind the easy service call on the GFI, seemed like over enforcement to me though.
Wood alcohol: Cannot be made non-poisonous.
Of all the lessons dad could have left out...
busymnky is offline   Reply With Quote
Old 10-31-2009, 07:42 PM   #31
Senior Moment
rlc3854's Avatar
But exactly HOW MUCH are you willing to pay to save one life? One Million $, Five Million $?? If we implement a safety regulation that costs more $ (and all do) then we must do a $ trade off on cost effectiveness. Otherwise, we can come up with some VERY undesirable (but effective) "safety changes".
I just maintain that some of the more recent changes do not offer any reasonable payback in human lives saved vs cost. Since I cannot find even ONE life extingushed by a faulty GFCI unit, I suggest that adding TR protection to something already about 100% effective is simply costly, frivolous and not productive of added safety to people.
Try looking outside your narrow box for what the code process brings over a period of time. After all some back in the day counldn't understand the need to change knob and tube wiring, why add a grounding conductor to the circuit and the list goes on. As in any safety practice all it takes is one accident and a lawsuit to start practice that seems to make no sense. I was always taught to use gloves when using a 535 threading machine yet now the safety guys tell you no.
www.resqmefarmscattery.com
rlc3854 is offline   Reply With Quote
Old 11-01-2009, 06:58 PM   #32
Professional Nit Picker
[quote=480sparky;136305]To answer 1).:
406.11 Tamper-Resistant Receptacles in Dwelling Units.
In all areas specified in 210.52, all 125-volt, 15- and 20-ampere receptacles shall be listed tamper-resistant receptacles.
210.52(A) General Provisions. In every kitchen, family room, dining room, living room, parlor, library, den, sunroom, bedroom, recreation room, or similar room or area of dwelling units, receptacle outlets shall be installed in accordance with the general provisions specified in 210.52(A)(1) through (A)(3).
(B) Small Appliances.
(C) Countertops
(D) Bathrooms.
(E) Outdoor Outlets.
(F) Laundry Areas.
(G) Basements and Garages. For a one-family dwelling, the following provisions shall apply:
(1) At least one receptacle outlet, in addition to those for specific equipment, shall be installed in each basement, in each attached garage, and in each detached garage with electric power.
(2) Where a portion of the basement is finished into one or more habitable rooms, each separate unfinished portion shall have a receptacle outlet installed in accordance with this section.
(H) Hallways.
OK 480-
Lets play devils advocate here -
What about those outlets above 5 1/2 feet off the floor, or inside cabnets? Some will say that according to the very beginning of 210.52 these are excluded???
Old 11-01-2009, 07:08 PM   #33
Originally Posted by manchestersparky View Post
OK 480-
Those would not need to be TR. If you put a rec. every 6' then every other one would need to be TR.
Old 11-01-2009, 07:21 PM   #34
Not Peter D
Bob Badger's Avatar
I disagree, 210.12 does not say all receptacles required by 210.52 it says all areas specified by 210.52
Old 11-01-2009, 07:24 PM   #35
I disagree 210.12 is for AFCI's we are talking about 406.11.
Old 11-01-2009, 07:27 PM   #36
Not Peter D
Bob Badger's Avatar
Brain fart, I was talking AFCIs a few minutes ago.
Oh well apply what I said to 406.11
Old 11-01-2009, 07:30 PM   #37
210.52 requires a rec every 12' and if you got one every 6' feet than only every other one would need to be TR. I would not install it that way but just saying.
Old 11-01-2009, 07:34 PM   #38
Not Peter D
Bob Badger's Avatar
No, everyone of them installed in that area will have to be TR.
Here is the wording
Notice it does not say all receptacles required, it says all areas specified, that is the difference.
Here is Mike Holt's take on it from EC&M Mag.
406.11 — TAMPER-RESISTANT RECEPTACLES IN DWELLING UNITS
Requirements for tamper-resistant receptacles were added to the 2008 NEC.
In dwelling units, all 15A and 20A, 125V receptacles shall be listed as tamper resistant.
Author's comment: This rule applies to receptacles installed behind appliances, above countertops, and other locations out of the reach of children.
This new section requires the use of listed tamper-resistant receptacles for all 15A and 20A, 125V receptacles installed in dwelling units.
Old 11-01-2009, 08:10 PM   #39
Well damn I had a brain fart also.
Old 11-01-2009, 08:38 PM   #40
Not Peter D
Bob Badger's Avatar
It looks like they might loosen it up a little for 2011 by adding some exceptions.
Here is a draft of the 2011 but it could change.
406.12 Tamper-Resistant Receptacles for Dwelling
Units.
In all areas specified in 210.52, all nonlocking type
tamper-resistant receptacles. [ROP 18-62, 18-68]
Exception No. 1: Receptacles located more than 1.7 m
(51⁄2 ft) above the floor. [ROP 18-71]
Exception No. 2: Receptacles that are part of a luminaire
or appliance. [ROP 18-71]
Exception No. 3: A single receptacle or a duplex receptacle
for two appliances located within dedicated space for
each appliance that in normal use is not easily moved from
one place to another and that is cord-and-plug connected
in accordance with 400.7(A)(6), (A)(7), or (A)(8). [ROP
18-71]
Exception No. 4: Nongrounding receptacles used for replacements
as permitted in 406.4(D)(2)(a). [ROP 18-82]
DC and receptacles Golden Arc General Electrical Discussion 7 04-03-2009 06:16 PM
Load Calc. for Old Single Family Dwellings Reseman Services and Service Equipment 5 05-31-2008 09:21 AM
Article 725 - CL2x vs. CL2 vs. CL2R in Dwellings BillS NEC Code Forum 2 03-14-2008 09:23 AM
Childproof Receptacles Nosparxsse NEC Code Forum 13 01-26-2008 09:44 AM
Electrical in existing dwellings MDShunk Other Codes and Standards 3 01-11-2008 08:54 PM
