Old 08-26-2008, 06:33 PM   #1
Always Learnin'
Default Need Code reference
I have an installation I mentioned in an earlier thread where the service is 120/240 1Ø 320A meter/main with (2) 200A circuit breakers. One of the 200A breakers in the meter/main feeds a 200A MB panel back-to-back with the meter/main. The other 200A breaker feeds an addition to the main building via 2" PVC conduit underground to another 200A MB panel. Both of these feeders are 4 wire copper(3/0,3/0,3/0,#2)and both panels have the neutral isolated from the egc. The inspector claims I cannot have a main breaker in the panel located in the addition. He says it must be a MLO panel. I asked for a code article and he couldn't provide me one. He will be doing a final inspection later this week and I know it will come up again. I have searched the 08 NEC and cannot come up with a clue as to where he is getting this idea. I would appreciate any thoughts on this.
amptech is offline   Reply With Quote
Old 08-26-2008, 06:51 PM   #2
I don't think you will find anything that tells you that you can not do that.
Stand your ground and make him prove a code reference.
You can tell him it is not a breaker, but a panel disconnect!
GO JACKETS!
jbfan is offline   Reply With Quote
Old 08-27-2008, 11:50 AM   #3
Ax grinder
raider1's Avatar
I agree with jbfan. There is nothing in the NEC that prohibits a main breaker in a panel. I would ask for a code reference from the inspector if he calls you on it at the final.
Chris
raider1 is online now   Reply With Quote
Old 08-27-2008, 05:28 PM   #4
Always Learnin'
I called the State Building Department today and spoke with the Electrical Code Enforcement Officer. He says the local inspector is incorrect and if he refuses to supply me with a code article reference and still fails me I am to report him to the State Building Department immediately.
Old 08-27-2008, 05:56 PM   #5
Ax grinder
raider1's Avatar
Good to hear that the state building department has your back.
Chris
Old 08-28-2008, 05:49 AM   #6
chenley's Avatar
I would have failed my last house inspection if that were true. Ended up throwing in a 200A SQD Homeline for a main panel, then the same for a sub-panel upstairs. The whole first story minus the kitchen was feed off the main panel, then the whole second story plus first story kitchen was feed off of the sub-panel.
Old 08-28-2008, 06:39 AM   #7
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
The inspector is completly wrong. I like the idea of being able to shut the whole panel off at the panel. Like jbfan said "its a panel disconnect" I have installed many main breaker panels as sub panels. Every single one has passed and never questioned.
~Matt
Old 08-28-2008, 07:13 PM   #8
Always Learnin'
The code official at the State level called me back today while I was at the job awaiting the inspector for the final. He assured me I was correct and that he had looked in to the situation in the jurisdiction I was working in. He told me to call him immediately if there was any problem during my final. The inspector showed up 2 hours late(this job is 160 miles from my home and I was there 2 hours early) was all smiles and handshakes, looked around for 5 minutes, said everything looked great and he would send out the CO in the mail next Tuesday and left. I think the State guy had a word with someone.
Old 09-07-2008, 01:17 PM   #9
NEC Educator & Consultant
TheElectricalGuru's Avatar
Send a message via AIM to TheElectricalGuru
Agreed....What we do not need is inspectors "creating" code on site. The problem is so many local inspectors are in programs where their is no budget to get them the additional training they need and everyone suffers.
Hopefully this will change as more states demand CEU requirements and the educators step up to the plate and really educate them. Sad part is many states require the electricians to do CEU but some dont require the inspectors to do the same...but thats changing thank goodness.
Paul W. Abernathy,CME,RMS,CMI
Master Electrician/Electrical Educator/NEC Consultant
ICC & IAEI Certified Electrical Inspector/Plans Examiner
www.TheElectricalGuru.com
TheElectricalGuru is offline   Reply With Quote
Old 09-08-2008, 08:26 AM   #10
Newbie question...
Is it common for inspectors to let the term "Authority Having Jurisdiction" go to their head and just make up whatever they want?
AWKrueger is offline   Reply With Quote
Old 09-08-2008, 07:04 PM   #11
Always Learnin'
I have ran into inspectors in the past who believed they were the "Authority Having Jurisdiction" and tried to enforce their personal preferences. It doesn't fly in Indiana that way. The AHJ is the governing body that adopted the Code in the jurisdiction. If they adopted the code as it was adopted by the State of Indiana they have to enforce it as it was adopted by the state. No local amendments are allowed to the Uniform Code adopted by the State of Indiana. If a local inspector tries to enforce something outside of the code as adopted by the state, you just do as I did and call the state and let them deal with the inspector.
Old 09-10-2008, 08:34 AM   #12
It seems in michigan you don't hear much about people going over inspectors heads to get a decision changed. Usually it's alot of bitching and then just doing what they ask. I suppose it depends on the circumstance.
'09 ICC code thekctermite General Electrical Discussion 0 10-20-2008 10:49 AM
2008 Code Changes gilbequick NEC Code Forum 40 01-19-2008 09:36 AM
National Electrical Code: Analysis & Explanation of the Underwriters' Electrical Code Joe Tedesco Vintage Electrical 3 12-29-2007 12:47 AM
Code book vs. Code book "Handbook" shotdown General Electrical Discussion 14 09-10-2007 01:39 PM
NEC reference article???? dora NEC Code Forum 38 03-19-2007 02:51 PM
