Old 06-20-2008, 06:58 PM   #1
Default neutral conductor
2008 NEC Handbook, p 30, Exhibit 100.11. Should one of the batteries in the fourth example have its poles reversed in order to make the labeled conductor a neutral point? As I see it as printed, DC voltages add in series, so the labeled conductor is actually at positive voltage.
chollapete is offline   Reply With Quote
Old 06-20-2008, 07:01 PM   #2
nap
a real PITA
there is no neutral in DC voltage.
there is Positive and negative
any chance of showing the drawing? I don;t use the handbook and don't have access to one.
Old 06-20-2008, 07:37 PM   #3
JohnJ0906's Avatar
I think you mean Exhibit 100.12.
Originally Posted by 2008NEC
"Neutral point - The common point on a wye-connection in a polyphase system or midpoint on a single phase, 3-wire system, or midpoint of a single-phase portion of a 3-phase Delta system, or a midpoint of a 3-wire, direct-current system"
I'm not sure about the pole orientation part of your question.
John from Baltimore
"One day at a Time"
Old 06-20-2008, 07:59 PM   #4
my only Internet now is EDGE on an iPhone. Can't scan and attach a drawing. Yes, I mean 100.12.
By "pole orientation" I mean: the figure shows two batteries in series, with a conductor brought out from between the two cells. They are calling that center conductor the "neutral point". (One of the other two conductors is connected to one cells positive terminal; the other conductor is attached to the other cells negative terminal.) To get something akin to a neutral, you could reverse the polarity of one of the cells, so the "neutral conductor" is now connected to both negative terminals and each of the other two is attached to a positive terminal.
Wish I could draw a picture--the concept of neutral point in a DC circuit doesn't grok for me.
Old 06-20-2008, 08:20 PM   #5
nap
a real PITA
that is the neutral point.
My misreading concerning your post lead to my mistake and possibly the way I was taught.
if you can go to this link, I believe it shows what you are speaking of but with generators rather than batteries. Go on down to page 7.
Is this the same (other than the gens instead of batts)?
Loose Conductor brian john Workplace Safety 14 11-07-2009 05:12 PM
conductor question THREEPHASE NEC Code Forum 4 05-05-2008 11:38 PM
compact conductor olectric General Electrical Discussion 16 02-07-2008 07:47 PM
120 v in neutral??? lamino69 General Electrical Discussion 10 01-14-2008 09:34 PM
Neutral? brian john NEC Code Forum 14 04-10-2007 11:55 AM
