Noalox (anti-oxidant) - Electrician Talk - Professional Electrical Contractors Forum
Old 06-29-2011, 02:07 PM   #1
Nosparxsse's Avatar
Rewards Points: 150
Default Noalox (anti-oxidant)
Code reference? is there one?
Nosparxsse is offline   Reply With Quote
Old 06-29-2011, 02:54 PM   #2
Ax grinder
raider1's Avatar
Rewards Points: 1,080
110.3(B) you only need to use an antioxidant compound if the manufacturer requires its use. Either the wire manufacture or the equipment manufacture.
Most likely you will not need to use it.
Chris
Old 06-29-2011, 02:58 PM   #3
kennydmeek's Avatar
Rewards Points: 502
In my world if it's aluminum inspectors want to see it on there. Never seen one look to see if it's actually at point of contact... They just want to see it...
kennydmeek is offline   Reply With Quote
The Following User Says Thank You to kennydmeek For This Useful Post:
Charlie K (06-29-2011)
Old 06-29-2011, 04:02 PM   #4
Ax grinder
raider1's Avatar
There are lots of inspectors that want to see NoAlox smeared all over the lugs but that does not mean that it is required.
Chris
Old 06-29-2011, 04:07 PM   #5
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
Chris
and to really do it proper, you need to get into the individual conductors of the cable, not just the surface
I'd rather be sleeping.
Old 06-29-2011, 04:37 PM   #6
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Yep, that's why I peel the label off all my no ox. The instructions say to work it into the cable using Emory cloth. How many of us do that? I take off the label so an inspector wont pick the bottle up and read it, and then ask if I did that. So all my no ox bottles have no labels...
AWKrueger (07-04-2011)
Old 06-29-2011, 04:42 PM   #7
Ax grinder
raider1's Avatar
Ask the inspector where NoAlox is required.
I have not seen any new panel manufactures that require the use of an antioxidant compound on the lugs when using Aluminum wire.
Chris
Old 06-29-2011, 04:45 PM   #8
Ax grinder
raider1's Avatar
Exactly, I know of inspectors area my area that want to see NoAlox on all aluminum terminations and don't care if someone just applies the stuff on the lug after the wires are terminated.
Gooping antioxidant paste on a terminated lug is a huge waste of time and makes a hell of a mess. But that makes some inspectors all warm and fuzzy and able to sleep at night.
(End Rant)
Chris
Old 06-29-2011, 05:17 PM   #9
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
I have used a wire brush to put it on once...It makes a huge mess...I never even use the stuff anymore...but its funny everyone says that, b/c they all want to see it on the lugs like its a code or something...
REMOVED
Old 06-29-2011, 07:03 PM   #10
Rewards Points: 2,000
I dip my aluminum conductors in it. Doesn't cost much and could help some. Why not use it? Aluminum doesn't conduct well when it oxidizes. Compared to copper which does conduct when it oxidizes.
Old 06-29-2011, 07:07 PM   #11
child please.....
Rewards Points: 14
My understanding is doing that really does nothing. You need to use something abrasive to work it into the wire...
REMOVED
Old 06-29-2011, 07:13 PM   #12
I don't know, can't hurt. I figure I'm at least decreasing the chance of corrosion. I work the Noalox up to the wire insulation and try to get it on all the wire surface. I like the clearish stuff. The Ideal stuff is pretty nasty.
I've had good luck with coating my battery terminals with Permatex anti corrosion spray. I don't wire brush it on. I know not the same thing but it seems similar.
Old 06-29-2011, 07:40 PM   #13
Mike in Canada's Avatar
You're not working it into the wire... you're removing the oxidation layer and the goop is not allowing it to re-form.
Mike in Canada
Makin' it up as I go along...
Mike in Canada is offline   Reply With Quote
Old 06-29-2011, 09:07 PM   #14
child please.....
Rewards Points: 14
There is always one. I'll leave it at that
REMOVED
Old 06-29-2011, 09:19 PM   #15
220/221's Avatar
Rewards Points: 3,556
That's one of those things I just do instead of arguing about it.
Just squeeze a dab after termination so they see it.
Old 06-29-2011, 09:25 PM   #16
One thing I hadn't thought about was the POCO doesn't use Noalox when they connect over head drops in my area. If it was a real problem you would think that you would see more problems with the overhead terminations. Maybe I am just wasting time and making a mess. Or maybe there is some of the stuff inside their connectors..
Old 06-29-2011, 09:28 PM   #17
Tabihu Juhar
76nemo's Avatar
You're looking to raise a few flags here, correct? I know you're not serious.
Old 06-29-2011, 09:54 PM   #18
Jlarson's Avatar
Rewards Points: 2,792
I haven't put noalox on lugs in quite a long time. Like Raider said usually not required.
I've done the same as 220 if I'm dealing with an inspector I know will bitch and I just want the job passed and don't feel like arguing.
Old 06-29-2011, 09:57 PM   #19
Rewards Points: 250
These guys are right.
Its a recomendation by some manufacturers. Or should I say - it used to be a recomendation by some manufacturers.
I use it. I dont know why I dont throw it away. Having the proper torque on the connections is much more important in my view.
ralph is offline   Reply With Quote
Old 06-29-2011, 10:39 PM   #20
NRA Member
backstay's Avatar
Rewards Points: 750
I see it inside these. Thomas & Betts Blackburn Description:2-2 Serv Ent Splice
therain (02-28-2013)
Saftey glasses with anti fog Pokesomi Tools, Equipment and New Products 23 10-23-2012 12:52 PM
Charlie ..... anti-winning BBQ Off Topic (Non Trade) 13 04-03-2011 07:26 PM
Anti-Virus soft... Norcal Off Topic (Non Trade) 15 03-26-2010 12:27 AM
Anti-shorts required? ssandoval NEC Code Forum 66 09-12-2009 11:33 PM
Noalox... waco General Electrical Discussion 27 04-29-2009 10:40 AM
