nyc electrical code and building codes - Electrician Talk - Professional Electrical Contractors Forum
Old 05-13-2009, 08:53 PM   #1
Default nyc electrical code and building codes
i am getting violations from city inspectors on the bond wire from panel to transformer they are saying that the size of the bond wire must be as large as the feed wire.
fa inspectors are now giving violations on the ground wire for a fuse cut out thay say it should be a number 8 wire not 10.
anyone know where i can read this in black and white i cant seem to find it anywhere
grumpy is offline   Reply With Quote
Old 05-13-2009, 11:22 PM   #2
The instructor that taught one of our transformer classes in the apprenticeship said the same thing. But I don't agree with it yet.
Read 250.102(c) and (d). They send you to table 250.122 for sizing. 250.102(d) says it shall not be required to be larger than the largest ungrounded circuit conductors.
Anyone else?
NevadaBoy is offline   Reply With Quote
Old 05-14-2009, 01:22 AM   #3
I don't think I had that right. Start with 250.30.
I believe you size off Table 250.66.
Old 05-14-2009, 08:22 AM   #4
Speedy Petey's Avatar
Rewards Points: 2,134
Grumpy, did you ask them what they are basing these violations on?
Old 05-22-2010, 02:19 PM   #5
Local 3 IBEW
I just heard this from a Fire Alarm vendor yesterday, but also no proof.
Special Ed is offline   Reply With Quote
Old 10-08-2012, 09:34 AM   #6
Local 3 IBEW
The one line diagram on the approved, stamped as-builts, show what the inspector will look for.
Most cases it's a #8 solid green from building steel to the Fused Disconnect Switch (FDS) and then a #10 solid green to the equipment. Be sure to use a #8 double lug to transition the two size wires in the FDS and also terminate the #10 solid neutrals on the isolated neutral bar in the switch.
Old 10-08-2012, 09:42 AM   #7
icefalkon's Avatar
Rewards Points: 570
Hey SE, welcome to the forum. Our Fire Code is different than many other locations...in some area's it's still a number 10AWG. We changed that in 2008 I believe.
Again, welcome!
Steve from NYC
Local Union #3 IBEW NYC
"Eternal Vigilance is the price of Good Unionism" Harry Van Arsdale Jr.
icefalkon is offline   Reply With Quote
Old 10-08-2012, 09:44 AM   #8
icefalkon's Avatar
Rewards Points: 570
Here's a transformer drawing I was asked to come up with for the Bonding and Grounding Course we teach
Steve from NYC
Old 10-08-2012, 09:51 AM   #9
icefalkon's Avatar
Rewards Points: 570
Complete BS. And now we have 35 new inspectors who are violating everything they can. Remember, here in NYC now there is now a fine attached to any life threatening Class 1 Violation
Yes, you can find this in the 2008 NY Fire Code
Hope that helps.
Steve from NYC
Old 10-08-2012, 10:35 AM   #10
Local 3 IBEW
Thanks Steve! I was just commenting on the Fire Alarm portion of Grumpy's question but thank you for that great diagram.
I am on the mailing list for the Grounding/Bonding class but have not heard of a start date yet.
Old 10-08-2012, 11:15 AM   #11
icefalkon's Avatar
Rewards Points: 570
We're running a class now. The next round will probably be in January. It and Electric Vehicles are two insanely popular classes right now. I teach Code and EV to AJ's...Code and Solar to Apprentices. Sign up for everything you can. The B&G is probably our best course to date and it's only getting better.
Thanks for the props for the diagram. When the App Dept asked me for a diagram I was asked to show the 5th Fl. Next thing I knew they put it in the course book lol. We're trying to keep the AJ's and App's training synced up.
Steve from NYC
Old 10-08-2012, 06:02 PM   #12
Rewards Points: 25
#8 is the smallest grounding electrode you're allowed to use,since the fused disconnect is normally tapped ahead of the main switch it's considered a service switch.Although most FA vendors list it as solid on their drawings I've had no problem using stranded.
cmac1 is offline   Reply With Quote
Old 10-08-2012, 07:30 PM   #13
icefalkon's Avatar
Rewards Points: 570
Same here. I've never had a problem with a Marshal inspecting the FA when he see's it's stranded. They look for the major no no's...did you splice the connection, did you follow Advisory Board Drawings, etc.
Steve from NYC
evolution of the national electrical code john laurie NEC Code Forum 2 02-22-2009 08:10 PM
E-Codes - Municipal Codes on the Internet Speedy Petey Other Codes and Standards 1 10-28-2008 10:22 PM
Building Electrical Services - whose responsibility BIGEYE General Electrical Discussion 1 02-01-2008 07:17 AM
Different local codes goose134 General Electrical Discussion 20 01-16-2008 10:30 AM
National Electrical Code: Analysis & Explanation of the Underwriters' Electrical Code Joe Tedesco Vintage Electrical 3 12-28-2007 11:47 PM
