Old 09-19-2007, 12:26 PM   #1
Default Outdoor lighting and GFCI
Outdoor receptacles are required to be GFCI protected.
For an outdoor light mounted on the side of the house, wet location, and the switch being indoors, would the circuit need to be GFCI protected?
Would the answer to the above be the same for a circuit running to a lamp post?
thanks
shocking is offline   Reply With Quote
Old 09-19-2007, 01:17 PM   #2
No. And yes, the answer is the same.
The NEC is quite clear as to GFI requirements in residential settings. I suggest you read up on 210.8.
Old 09-19-2007, 03:16 PM   #3
... I was looking all over the NEC for the answer and all I found was GFI requirement for outdoor receptacles. Which I knew about. I could not find anything on outside lighting fixtures.
So thanks for the answer..
Old 09-19-2007, 07:10 PM   #4
JohnJ0906's Avatar
Not required to be GFCI protected, but, in a residential setting, you would be able to bury the wire at 12" as opposed to 18"
300.5 ( I think, NEC not with me)
John from Baltimore
"One day at a Time"
Old 09-19-2007, 08:34 PM   #5
JohnJ0906's Avatar
I'm correct on the 300.5 part, but incorrect on the 18" part. Direct burial cables under a residential lawn would be 24" (non-GFCI protected)
John from Baltimore
"One day at a Time"
Outdoor E-stop heel600 General Electrical Discussion 6 03-26-2009 11:28 PM
Small 12-24 for outdoor JamesINla Services and Service Equipment 3 11-18-2008 12:10 AM
Outdoor lighting and primaries... waco General Electrical Discussion 5 10-11-2008 02:52 AM
outdoor sign lighting rebel34 General Electrical Discussion 3 03-29-2008 08:49 AM
Outdoor Lighting - LED vs. Halogen philsig Tools, Equipment and New Products 2 01-09-2008 05:39 AM
