Old 04-30-2012, 07:03 PM   #1
Default Pool light bond issue
A pool built in the ealy 70's has sch40 brass conduit from the light to the first junction box. A tree was planted right next to the junction box and the box was set at grade. Forward nealy 40 years and the tree has almost grown around the junction box. Was able to dig down to a mid-point on the brass conduit and also find the rigid conduit on the other side of the tree. Cut threads on the existing brass, installed a threaded brass union, ran new brass around the tree to the other side and up above grade to relocate the junction box. From there tied into the rigid conduit.
Inspector comes out and says the brass has to be "UL listed".
My dilema: How to verify the new sch40 brass conduit is "UL listed"
Any advice where/how to do that?
Thanks
y_erd_right is offline   Reply With Quote
Old 04-30-2012, 07:08 PM   #2
B4T
ET Road Warrior
B4T's Avatar
You should of asked the inspector since he is making up his own rules..
Old 04-30-2012, 07:12 PM   #3
Heavily Armed Member
HARRY304E's Avatar
Originally Posted by y_erd_right View Post
A pool built-in the early 70's has sch40 brass conduit from the light to the first junction box. A tree was planted right next to the junction box and the box was set at grade. Forward nearly 40 years and the tree has almost grown around the junction box. Was able to dig down to a mid-point on the brass conduit and also find the rigid conduit on the other side of the tree. Cut threads on the existing brass, installed a threaded brass union, ran new brass around the tree to the other side and up above grade to relocate the junction box. From there tied into the rigid conduit.
My dilemma: How to verify the new sch40 brass conduit is "UL listed"
Thanks
That's great ,but how does the inspector intend to enforce this imaginary rule when the fact is the pipe has been there for 40 years You Are not the original installer you just did the repair on it.
What does he want you to re-pipe the whole job?
BTW ,Welcome to the forum....
Old 04-30-2012, 07:26 PM   #4
Good at being Evil
Shockdoc's Avatar
The inspector needs to stop smoking ***** out of a stem, it's making him paranoid.
Old 04-30-2012, 07:28 PM   #5
Thanks Harry, and B4T. Yea, is not like some exotic brass alloy was in place. It's red, or yellow, brass I spliced into the existing brass, ran it anew around the tree--all bonding in place via same metal throughout--and to the junction box.
The inspector said he was a "temp" so I highly doubt I'll get the same guy for a sign-off.
Still, if his picking fly sh_t is gonna be an issue, any thoughts?
Old 04-30-2012, 09:59 PM   #6
k_buz's Avatar
'Round here, we don't need to pull permits for repairs.
k_buz is offline   Reply With Quote
Old 05-01-2012, 11:29 AM   #7
979
get a UL sticker and put it on the fitting. then tell him go back the the circus he came from.
979 is offline   Reply With Quote
Old 05-01-2012, 11:49 AM   #8
Electrical Simpleton
Pete m.'s Avatar
Thanks
If it is UL listed it will be either a stamp in the metal or a sticker or painted directly onto the conduit.
Where did you purchase the brass pipe from? Is it electrical conduit or plumbing pipe?
Pete
Confidence is the feeling you have before you understand the situation.
Pool water bond nrp3 General Electrical Discussion 27 06-06-2011 09:36 PM
Pool grid bond Magnettica General Electrical Discussion 57 04-19-2011 09:40 PM
swimming pool bond for water jbarges General Electrical Discussion 4 07-11-2010 10:44 PM
Pool light for water bond.. B4T General Electrical Discussion 27 05-14-2010 01:38 PM
pool water bond: leland NEC Code Forum 42 05-07-2010 05:53 PM
