Receptacle above baseboard heat - Electrician Talk - Professional Electrical Contractors Forum
Old 06-23-2010, 12:33 PM   #1
Rush Chairman
Otter's Avatar
Default Receptacle above baseboard heat
Are there any restrictions on putting
receptacles above baseboard heat? Can I put a receptacle above a
baseboard heater knowing full well that someone will plug something into
the receptacle and allow the cord to drape over the baseboard heat? If
yes, does it depend on the type of heat - radiant heat vs electric
baseboard for example?
Is there a different ambient temp in the wall for derating of the wire?
Otter is offline   Reply With Quote
Old 06-23-2010, 01:12 PM   #2
424.9 fpn: 08 code
voltz is offline   Reply With Quote
Old 06-23-2010, 01:18 PM   #3
Rewards Points: 574
To add to what Voltz has written, I will say that I have never seen an electric baseboard heater that would allow a receptacle to be installed above it.
Here is the accessory to accommodate code. They mount at the ends of the heaters. I have done a few this way but not for 20 years or more.
Old 06-23-2010, 01:41 PM   #4
Rush Chairman
Otter's Avatar
What about a height requirement? Could I put a recep. 7 ft above the unit and be alright?
Old 06-23-2010, 01:45 PM   #5
Rush Chairman
Otter's Avatar
Could I put a recep. in the floor in front of the baseboard?
Old 06-23-2010, 01:45 PM   #6
Electric Al
oldtimer's Avatar
Rewards Points: 2,306
I also did some like this many years ago, but I never liked it. My reason is;
Most electric baseboard heaters operate on 240/208 volt. Therefore you had to bring a 120 volt line to the receptacle, and by code the unit would have to be identified as having more than one power.
Old 06-23-2010, 02:01 PM   #7
Rewards Points: 574
Not sure what code that is but anyone should be able to see that there would be 2 power sources. I never labeled it. Maybe back then it wasn't necessary.
Old 06-23-2010, 02:03 PM   #8
Rewards Points: 574
The NEC does not address this. It would be in the manufacturers instructions. I seem to remember something like 4' or so.
Yes, the purpose is to keep cords from draping ontop of the heater. I don't believe there is an issue with a floor recep. in front of the unit.
Old 06-23-2010, 02:04 PM   #9
Rewards Points: 2,050
Canada ........ the great white North ehh?
Old 06-23-2010, 02:04 PM   #10
Fried Bologna um um good!
jwjrw's Avatar
Or maybe it was and you missed it!
Old 06-23-2010, 02:06 PM   #11
Rewards Points: 574
Here are some instructions from a Cadet heater. Seems like no recep. is allowed above the heater at any height.
1. Read all instructions before using this heater.
2. Read all information labels. Verify that the electrical supply
wires are the same voltage as the heater.
3. All electrical work and materials must comply with the
National Electric Code (NEC), the Occupational Safety and
Health Act (OSHA), and all state and local codes.
4. The heater must be grounded to the grounding pigtail (copper
wire) provided.
5. If you need to install a new circuit or need additional wiring
information, consult a qualified electrician.
6. Protect electrical supply from kinks, sharp objects, oil, grease,
hot surfaces or chemicals.
7. Do not place heater against paperboard or low-density
cellulose fiberboard surfaces.
8. Do not place heater below an electrical convenience receptacle.
Placement
For best results, install the baseboard heater under a window, along
an outside wall, or as close as possible to an outside door. Follow
these instructions for selecting an ideal area of installation:
the heater may need to be caulked to prevent dust from being drawn into the room.
Heater should be set flush against surface of the wall.
Remove any obstructions between the back of the unit and the surface of the wall.
Baseboard heater may sit directly on any floor surface, including carpet.
Do not allow carpet to block lower air intake located 1 inch from the bottom of the heater.
Maintain at least 12 inches minimum clearance from objects hanging above (i.e. drapes).
Old 06-23-2010, 02:11 PM   #12
Electric Al
oldtimer's Avatar
Dennis; Our code is the C.E.C. There are amendments for specific provinces. You have amendments for specific states I think.
Old 06-23-2010, 02:12 PM   #13
Edrick's Avatar
Rewards Points: 1,582
heh someone doesn't want to come to this new house then. The whole house is wired with electric baseboard heating and it's under every window basically and under every outlet in the house. It'd be impossible to follow code to meet the minimum distance of outlets if they didn't put it over the baseboard heating.
Edrick is offline   Reply With Quote
Old 06-23-2010, 02:15 PM   #14
Rewards Points: 574
Floor recep. would make it compliant and recep. in the end of heaters. Why would that not work?
Old 06-23-2010, 02:16 PM   #15
Edrick's Avatar
Good question I suppose that would of worked however I didn't wire the place a Master Electrician built the house back in 1995 so perhaps the rule wasn't in effect back then.
Old 06-23-2010, 02:18 PM   #16
Rewards Points: 574
Yes it was, the inspector didn't catch it would be my guess. It is not an NEC issue but a manufacturers spec.
Old 06-23-2010, 02:20 PM   #17
Rush Chairman
Otter's Avatar
Thanks for all the input. Would I be able to install a panel board above the baseboard since there would be no cords hanging.
Old 06-23-2010, 02:24 PM   #18
Rewards Points: 574
That depends-- technically it would violate 110.26
(3) Height of Working Space. The work space shall be clear and extend from the grade, floor, or platform to the height required by 110.26(E). Within the height requirements of this section, other equipment that is associated with the electrical installation and is located above or below the electrical equipment shall be permitted to extend not more than 150 mm (6 in.) beyond the front of the electrical equipment.
Old 06-23-2010, 02:25 PM   #19
Not 'imposable' at all and the job should fail.
Either use the receptacles that install in the baseboard or never run more than 12' continuous feet of baseboard heat.
Old 06-23-2010, 02:32 PM   #20
Electric Al
oldtimer's Avatar
In new construction, I have had to install 2 small heaters with a space between, to comply with the receptacle spacing rules. A little more work and expense. But an option.
Debate again on BASEBOARD heaters under receptacles brother General Electrical Discussion 13 02-15-2010 11:13 AM
baseboard heat estimation help(complete house) lynx82 General Electrical Discussion 74 09-22-2009 12:13 AM
Heat from dimmers emtarnold Residential Electrical Forum 7 07-17-2009 10:30 AM
240 Volt Baseboard and Floor heat question TomP General Electrical Discussion 3 03-09-2009 09:31 PM
ceiling heat BryanMD General Electrical Discussion 6 01-02-2009 09:28 PM
