05-25-2012, 12:45 AM
#61
Originally Posted by BBQ
They make that?
I think they discontinued black THHN. Not enough demand.
05-25-2012, 12:47 AM
#62
It costs money to put that plastic stuff around the copper. Since it's a GROUNDing electrode conductor, we use bare.
Awesome. When I have a long enough scrap of #6 THHN, I use it for the GEC.
#63
Resi Service Electrician
For mine, since stupid ahj wants #4 regardless of size of service I carry a roll of #4 thhn and use it for 100amp servce conductors and gec. And since its #4 no need for that plastic stuff.
"Understand one thing every one has a place in this trade, and no matter what your skill set I doubt you know it all." brian john
05-25-2012, 12:52 AM
#64
Chief Electron Relocator
Ah, we just buy it bare. Saves time & money.
05-25-2012, 12:54 AM
#65
I tend to run a lot of #4 also, but mostly to the GEC, since it often is exposed to physical damage. #6 won't cut it, in that regard.
05-25-2012, 01:00 AM
#66
You are such a tool.  I don't have to buy scrap wire to use as GEC's.
05-25-2012, 01:01 AM
#67
The inspectors in my area don't usually red tag #6 exposed.
05-25-2012, 01:03 AM
#68
I use my scrap 6 for hooking up subpanels n such.
05-25-2012, 01:06 AM
#69
"Exposed" is usually opened to interpretation, and pretty loosely in some areas. In some areas in CA you ca run 6 on the wall as long as it is strapped well and is not in high traffic areas or something similar, but others do not want it anywhere but in pipe or in wall.
05-25-2012, 05:23 AM
#70
976-EVIL
(3) Other structures permitted to be of Types III, IV, and V
construction except as prohibited in 334.12. Cables
shall be concealed within walls, floors, or ceilings that
provide a thermal barrier of material that has at least a
15-minute finish rating as identified in listings of firerated assemblies.
The Following 2 Users Say Thank You to mcclary's electrical For This Useful Post:
05-25-2012, 06:13 AM
#71
ET Road Warrior
Here are the different construction classifications.. http://www.korel.com/construction-type.asp
TYPE V - Wood-frame construction is the most combustible of the five building types. The interior framing and exterior walls may be wood. A wood-frame building is the only one of the five types of construction that has combustible exterior walls. This is the typical single-family home construction method. These buildings are built with 2x4 or 2x6 studs and load bearing walls, wood floor trusses or wood floor joist and wood roof framing.
05-25-2012, 06:30 AM
#72
ET Road Warrior
334.10 was a recent code change to allow exposed NM as stated.. otherwise we would have the same problem with exposed cables in basements..
. Installation
334.10 Uses Permitted. Type NM, Type NMC, and Type
NMS cables shall be permitted to be used in the following:
(1) One- and two-family dwellings and their attached or
detached garages, and their storage buildings.
05-25-2012, 06:31 AM
#73
. Installation
It was never an issue in a basement as that was part of the dwelling unit. The issue was detached garages and sheds on dwelling unit property.
05-25-2012, 06:35 AM
#74
ET Road Warrior
So a detached garage can have exposed NM using 2011 code but be red tagged if you're still on 2008 code..
05-25-2012, 06:59 AM
#75
Heavily Armed Member
What is in the 2008 NEC that would make it different?
In this case the inspector is just busting his chops IMO.
05-25-2012, 07:07 AM
#76
ET Road Warrior
the code change that was added for 2011..
05-25-2012, 08:23 AM
#77
976-EVIL
Yep, you're right.
05-25-2012, 05:56 PM
#78
PGW Professional
#10 to the intersystem bond?
(((( X ))))
#6 from the panel ground bus passing through to the ground rod.
05-25-2012, 06:01 PM
#79
PGW Professional
05-25-2012, 06:37 PM
#80
1,000,000th Poster
I have nothing to contribute other than the inspector who failed that is a dink.
Also:
Duct Seal Compound
Seals conduit openings against drafts, dust, moisture and noise.
• Protects terminal boxes, pot heads and bushings from corrosive elements.
• Deadens switch gear panel noise.
• Dough-like compound is easily “thumbed” over holes and gaps.
• Will not harden or form a skin under normal conditions.
• Not for use outdoors.
• Specifications:
- Viscosity: ASTM D-217 300-gram load - 7.0 -11.0; ASTM DS-S2
100-gram load - 9.0 -15.0
- Temperature Range: Adheres at -20 °F (-29 °C). Will not slump after
1 hr. at 350 °F (175 °C).
- Flash Point: Over 550 °F (285 °C).
- Other Properties: Non-conducting, non-deteriorating, non-toxic,
non-corrosive, non-staining, non-curable; 99% solid, coil-based.
I would love to see someone use duct seal to deaden noise from switchgear; I imagine something like The 3 Stooges, only with more fire.
-John
