Service entrance disconnect - Electrician Talk - Professional Electrical Contractors Forum
Old 04-14-2011, 11:21 AM   #1
reddog552's Avatar
Rewards Points: 127
Default Service entrance disconnect
I know the service entrance disconnect must be near the entrance of the service cable. Is there a rule how far from entering the building. Case in point,I was at a single famly dwelling which had an addition . The service entrance cables of a 200 amp service were ran from the meter cabinent through the addition in 2" rigid app.30' to the main panel.this instulation was inspected ? Is there a rule for how far unprotected cables can be run?
reddog552 is offline   Reply With Quote
Old 04-14-2011, 11:44 AM   #2
Salvatoreg02's Avatar
Rewards Points: 1,002
Our building requirement is less the 6' applies without protection. More then 6' then OCPD must be installed after the load side of the meter.
Sal
P.E.S
Salvatoreg02 is offline   Reply With Quote
Old 04-14-2011, 11:58 AM   #3
Rewards Points: 278
The NEC states as near as possible where the conductors enter the building. That being said many jurisdictions have amendments such as 10 feet, etc.
Old 04-14-2011, 03:37 PM   #4
Sideways Sparky
farlsincharge's Avatar
Rewards Points: 1,080
We are 6M (20'), any further and it has to be run in Rigid.
farlsincharge is offline   Reply With Quote
Old 04-14-2011, 03:42 PM   #5
Fried Bologna um um good!
jwjrw's Avatar
Commercial we can go up to 15ft in most cases in my home county. Residential they will usually let us go 1 bay over. No more that that. So basically 5ft or less. I would ask my AHJ.
Old 04-14-2011, 04:06 PM   #6
Ax grinder
raider1's Avatar
30' seems a little excessive to me but there may be a local amendment that allows that.
Chris
Old 04-15-2011, 08:50 PM   #7
Inspector
electures's Avatar
Rewards Points: 306
Up to the EI here. It used to be in the utility requirements.
electures is offline   Reply With Quote
Old 04-15-2011, 10:41 PM   #8
blueheels2's Avatar
Rewards Points: 296
This reminds me of the first house that I ever wired on my own. It was in Vermont and I was a 3rd year apprentice. At the time no license was required for residential. Setup was a 200 amp meter socket with main breaker disconnect mounted on a pedastal and then 200' to the house. The conduit entered the bldg. about 35' from the panel. I decided that this rule applied and some of my journeyman thought so as well so I mounted another disconnect inside. In retrospect I don't think it needed this disconnect because the conductors had ocp at the meter disconnect. Oh well.
blueheels2 is offline   Reply With Quote
Old 04-15-2011, 11:56 PM   #9
Rewards Points: 2,000
all the AHJs around here require an outside disconnect so we install meter/main combos if it is metered at the pole they require a disconnect on the house.
Mr Rewire is offline   Reply With Quote
Old 04-16-2011, 12:13 AM   #10
we have same thing here.. we call them house power panels, standard 200 amp. its just a meter socket with 12 throws below,(6)2pole throws cost about $120 each. also handy when wiring outside things like well pumps,a/c units etc. (not intended for single pole though,but alot of folks put single pole ckts on them)
rnr electric is offline   Reply With Quote
Old 04-16-2011, 12:29 AM   #11
I saw a guy do it once.
SparkYZ's Avatar
Rewards Points: 506
In California we use"all in ones" with the Meter, main, and loadcenter all in one enclosure.
SparkYZ is offline   Reply With Quote
Old 04-16-2011, 12:38 AM   #12
yup sounds like the same thing just different terminology.
Old 04-16-2011, 12:49 AM   #13
In canada there is a limit, I think like 10 feet or something, unless it's run under the slab. Can't just run it in rigid here I don't think.
kaboler is offline   Reply With Quote
Service Entrance Voltech NEC Code Forum 8 03-18-2011 12:40 AM
Old Service Entrance davis9 Vintage Electrical 7 12-04-2010 05:40 PM
Service Entrance silva.ac Services and Service Equipment 6 01-29-2009 06:51 PM
Service entrance walkerj Vintage Electrical 9 11-04-2007 01:06 AM
UG Service Entrance Hillbilly Services and Service Equipment 11 03-20-2007 10:33 PM
