I'm currently working on a vinyl pool and the city has just started applying the '08 code with respect to pool bonding. They're making us run an additional course of #8 bare copper buried 4 to 6" following the perimeter of the pool between 18 to 24" from the pool wall. It has to be attached to the inner run at 4 equidistant points.
Originally Posted by Speedy Petey
Yup. Bare or green. Either is fine. No conduit.
Be sure to hit EVERYTHING metal associated with the pool and within 5'.
Ladder cups, railing cups, coping, walls, light niche, diving board mount, motors, heaters, filters, salt generators, etc.
Oh, and don't forget the wonderful bonding of the water itself if you are under the 2008 NEC.
Would the bonding strip inside a wet niche forming shell suffice as water bonding?
