Old 04-24-2007, 08:39 AM   #1
Default Termination Conductor Spacing
If you look at this picture the mounting location of the neutral/grounded conductor was relocated. The neutral conductors have sufficient length to utilize the original location.
This 30 + year old building was currently remodeled, and it appears this transformer was relocated.
Old 04-24-2007, 04:40 PM   #2
The Lug they had on the truck did not match the hole layout
if they really had to scab it in, maybe some mastic could have been used for insurance!
faber307 is offline   Reply With Quote
Old 04-24-2007, 04:42 PM   #3
Especially between two primary legs. They'd have even had to scrub off the shellac for the new mounting location, when that was already done in the factory location. Strange.
Old 04-24-2007, 05:03 PM   #4
JohnJ0906's Avatar
I hope that isn't as close as it looks
John from Baltimore
"One day at a Time"
Old 04-25-2007, 02:10 AM   #5
"Euro" electrician
I hope my eyes is not teasing me but did the netural lug have 4 cables going in there ?? i know there is 2 for secondary side but what the heck going on primary side look like one netural or two grounding wires there and i am not sure if they did bonded the cabent with netural or ground hard to say there.
Merci, Marc
Old 04-25-2007, 09:43 AM   #6
DJFVT
John's Avatar
Merci, Marc
I saw that too and was wondering about it. It is hard to tell what the other 2 wires are, but there are 4 wires on that terminal.
The neutral connection is way too close the other phase connections for my comfort.
Carry On!
Conduit spacing chart. MDShunk General Electrical Discussion 30 02-23-2009 02:10 AM
neutral conductor chollapete NEC Code Forum 4 06-20-2008 08:20 PM
conductor question THREEPHASE NEC Code Forum 4 05-05-2008 11:38 PM
MWBC & Receptacle termination questions... Mackie General Electrical Discussion 17 04-10-2008 10:41 PM
Using the correct termination methods helps! Joe Tedesco Code Violation Discussion 10 03-26-2007 09:39 PM
