Old 04-23-2012, 06:52 PM   #1
Default thermostat
can thermostat and line voltage go through the same hole/comduit?
Julius793 is offline   Reply With Quote
Old 04-23-2012, 06:53 PM   #2
animal lover /rat bastard
wildleg's Avatar
depends. sometimes yes. mostly no.
Old 04-23-2012, 06:58 PM   #3
ok when yes when no? if its fed from a class 2 transformer what would the answer be?
Old 04-23-2012, 07:04 PM   #4
Good at being Evil
Shockdoc's Avatar
Same KO ? I believe yes. Same conduit? conductors need to be rated 600volts.
Old 04-23-2012, 07:24 PM   #5
wildleg's Avatar
maybe if you would provide more information it would be easier to answer you. hole in what ? control panel ? stud ? enclosure ? what voltage is the power ? is the thermostadt associated with the power wiring ? what type of wiring/cable is used for the thermostadt ? there are many variables.
Old 04-23-2012, 08:44 PM   #6
Agree with wild leg, many variables. Personally I keep different class circuits separate
Nebelectrician is offline   Reply With Quote
Old 04-23-2012, 08:48 PM   #7
1. holes in studs
2. 24v
3. not in any way
4. class 2
Old 04-23-2012, 09:08 PM   #8
wildleg's Avatar
is it 300v thermostadt cable ? is the power wiring over 300v ? is it one hole or a whole line of holes where the power and class 2 cable have no separation ? what about the conduit you mentioned before ?
Old 04-26-2012, 01:23 AM   #9
Within the last few months, 3 different jobs I've come on to towards the end have been called out by the inspector for running thermostat wire through the same hole in the studs as romex. By time I had gotten on the job and told the other guys, it was really too late to fix and they just figured the inspector wouldn't care. In 2 of the 3, it was the cause of the failure. Even holes up in soffits through the fire drywall require separate holes.
TLinSTL is offline   Reply With Quote
Old 04-26-2012, 10:48 AM   #10
Amish Electrician's Avatar
I'd love to see the citation.
Even taking Article 725 (I think) at it's most imaginative scope, it only addresses running Class 2 wires within the same wiring method - and a thermostat cable next to a Romex cable is still outside the Romex.
The 'mixing circuits' debate has plenty of life left in it, but I just can't see any ban on using the same hole.
Amish Electrician is offline   Reply With Quote
The Following User Says Thank You to Amish Electrician For This Useful Post:
Big John (04-26-2012)
Old 04-26-2012, 04:35 PM   #11
NacBooster29's Avatar
God make sure there's no plumbing in the same bay too. The electrons love to jump out of romex everyone knows that.
Old 04-26-2012, 08:42 PM   #12
WTF (where the fu--) did your inspector get that from? That makes no sense at all. The NM is insulated and jacketed, no leaking electrons to magically jump onto the unsuspecting (also insulated and jacketed) thermostat wire. Maybe you need to use the good NM cable that doesn't leak, then you will pass more inspections.
acrwc10 is offline   Reply With Quote
Old 04-26-2012, 08:54 PM   #13
B4T
ET Road Warrior
B4T's Avatar
I never heard of bell wire and NM cable in the same hole through a stud would lead to a violation.. that is crazy talk..
user4818 (04-26-2012)
Old 04-26-2012, 09:53 PM   #14
CABLES can share a knockout while CONDUCTORS cannot.
Old 04-26-2012, 11:48 PM   #15
PGW Professional
Magnettica's Avatar
Code section please.
The section the OP should be looking at is article 725. I believe it was one of the questions on the NJ licensing exam too. I looked just now but couldn't find it. I have it highlighted in my 08' NEC but that's out in the truck and i'm watching the Devils in OT so I'm not leaving this chair.
Old 04-26-2012, 11:56 PM   #16
I hardly ever read the code book anymore so I have no idea, but it's in there.
Old 04-27-2012, 12:08 AM   #17
Heavily Armed Member
HARRY304E's Avatar
300.2 Limitations.
(A) Voltage. Wiring methods specified in Chapter 3 shall
be used for 600 volts, nominal, or less where not specifically
limited in some section of Chapter 3. They shall be
permitted for over 600 volts, nominal, where specifically
permitted elsewhere in this Code.
(C) Conductors of Different Systems.
(1) 600 Volts, Nominal, or Less. Conductors of ac and dc
circuits, rated 600 volts, nominal, or less, shall be permitted
to occupy the same equipment wiring enclosure, cable, or
raceway. All conductors shall have an insulation rating
equal to at least the maximum circuit voltage applied to any
conductor within the enclosure, cable, or raceway.
Informational Note No. 1: See 725.136(A) for Class 2 and
Class 3 circuit conductors.
Informational Note No. 2: See 690.4(B) for photovoltaic
source and output circuits.
725.136 Separation from Electric Light, Power, Class 1,
Non–Power-Limited Fire Alarm Circuit Conductors, and
Medium-Power Network-Powered Broadband Communications
Cables.
(A) General. Cables and conductors of Class 2 and Class 3
circuits shall not be placed in any cable, cable tray, compartment,
enclosure, manhole, outlet box, device box, raceway,
or similar fitting with conductors of electric light,
power, Class 1, non–power-limited fire alarm circuits, and
medium-power network-powered broadband communications
circuits unless permitted by 725.136(B) through (I).
Old 04-27-2012, 12:10 AM   #18
HARRY304E's Avatar
typical.
Old 04-27-2012, 08:43 AM   #19
Originally Posted by HARRY304E View Post
typical.
What's typical? I have most of the important code rules memorized, so it's not like I need to study it.
Old 04-27-2012, 11:25 AM   #20
When I get an inspector that uses that method, I give them a run for their money. There is little room for "I know I read it somewhere" when your tell someone that they need to change something, thus delaying the job and costing money. One local inspector is almost afraid of me now because over the last 3 years everything he has called me on I challenged him on and proved him wrong. Nothing pisses me off more than uneducated inspectors, they are a public hazard by calling BS and missing real safety issues other trades work.
The Following User Says Thank You to acrwc10 For This Useful Post:
Magnettica (04-27-2012)
Thermostat wiring.. B4T General Electrical Discussion 9 07-28-2010 10:45 PM
Thermostat vmf214 Commercial Electrical Forum 3 11-15-2009 08:26 AM
3 wire thermostat drm General Electrical Discussion 8 11-10-2009 07:39 PM
Small cover for pulled throw thermostat wire, thermostat to be installed in fall personalt Structured Wiring 9 08-02-2009 10:02 PM
Help to set up thermostat on gas heater jayendra General Electrical Discussion 5 06-22-2007 08:39 AM
