Old 04-27-2012, 01:53 PM   #21
725.136(I) Other Applications. For other applications, conductors of Class 2 and Class 3 circuits shall be separated by at least 50 mm (2 in.) from conductors of any electric light, power, Class 1 non–power-limited fire alarm or medium power network-powered broadband communications circuits unless one of the following conditions is met:
(1) Either
(a) all of the electric light, power, Class 1, non–power-limited fire alarm and medium-power networkpowered broadband communications circuit conductors or
(b) all of the Class 2 and Class 3 circuit conductors are in a raceway or in metal-sheathed, metal-clad, non–metallic-sheathed, or Type UF cables.
(2) All of the electric light, power, Class 1 non–power-limited fire alarm, and medium-power network-powered broadband communications circuit conductors are permanently separated from all of the Class 2 and Class 3 circuit conductors
by a continuous and firmly fixed nonconductor, such as porcelain tubes or flexible tubing, in addition to the insulation on the conductors.
(1)(a) clearly permits the thermostat wire to be run though the same holes as the NM cable.
Magnettica (04-27-2012)
Thermostat wiring.. B4T General Electrical Discussion 9 07-28-2010 10:45 PM
Thermostat vmf214 Commercial Electrical Forum 3 11-15-2009 08:26 AM
3 wire thermostat drm General Electrical Discussion 8 11-10-2009 07:39 PM
Small cover for pulled throw thermostat wire, thermostat to be installed in fall personalt Structured Wiring 9 08-02-2009 10:02 PM
Help to set up thermostat on gas heater jayendra General Electrical Discussion 5 06-22-2007 08:39 AM
